Question about Toshiba Televison & Video
Toshiba 27wlt56b running xbox 360 by dvi to get hd on toshiba 27wlt56b can not get no sound or pic
4 Related Answers
Anonymous
  • 178 Answers
SOURCE: HD DVI HDMI problems.
As long as the phono socket is red or white. That represents Audio
Posted on Feb 13, 2008
Anonymous
SOURCE: No sound with HDMI cable and Xbox 360
FROM THE TOSHIBA MENU, (FIRST MAKE SURE YOU ARE SET TO
THE HDMI PORT THAT THE XBOX IS PLUGGED INTO) THEN SELECT
HDMI SETTINGS, UNPLUG HDMI CABLE FROM THE TOSHIBA TV (LCD
FLAT, MINE IS A 42") WAIT FOR THE SETTINGS TO HIGHLIGHT OR NOT
BE GRAYED OUT, THEN TURN OFF THE THREE SETTINGS, FOR COLOR
AND LIP-SYNC., SCROLL DOWN AND PRESS THE RESET BUTTON,
WAIT FOR MESSAGE TO APPEAR. TURN OFF THE TV AND PLUG IN THE XBOX.
TURN EVERY THING BACK ON. SEE IF IT WORKS.
NOT ALL CABLES ARE THE SAME AND NOT ALL TVS ARE THE SAME.
READ THE TV OWNERS MANUAL CAREFULLY, (RTFM), I FOUND A NOTE ABOUT
THESE SETTING ON THE SPECIFICATIONS PAGE.
Posted on Jul 13, 2009
Anonymous
  • 5 Answers
SOURCE: toshiba 27wlt56b dead psu
gdfg
Posted on Nov 18, 2009
Anonymous
SOURCE: hi, i resently bought a toshiba regza 42
I have the same problem. You need a new audio/video board.
Here is how mine sounds:
http://www.youtube.com/watch?v=yAXqWIhQYa4
Posted on Apr 30, 2010
I recently got a 51h83 toshiba tv. When i try to hook up my xbox 360 with the hd component cables in the back i get sound but no video. Please help.
WITH THE TOSHIBA 51H83TOSHIBA TV YOU CANT HOOK UP HD CABLES TO THAT SPECIFIC TV FROM YOUR XBOX 360 BECAUSE THE DEVICE ISNT EQUIPPED WITH THAT CAPABILITY
Nov 16, 2016 | Toshiba 51H83 51" Rear Projection...
How should I connect a Sony Wega KF-50WE620 to an XBox360 ?
Since the TV accepts HD signals only via DVI and component inputs, the only logical way is to use the "Xbox 360 Component HD AV Cable" as show in the link below:
How to hook up your Xbox 360 or Xbox 360 to TV
The TV will not accept a VGA input. A cable converting HDMI to DVI would also require that you break out the L + R audio channels, too. The one I mentioned above does this all for you with no degradation in video signals.
Mar 26, 2015 | Sony Grand WEGA KF-50WE620 Television
How do I get sound from my Xbox to my monitor via a hdmi lead - DVD lead
As far as I know, the DVI cable can't send sound, so if you could use a only-HDMI cable or SCART cable, that should give you both picture and sound.
Nov 11, 2012 | Microsoft Xbox 360 Console
No input signal VGA/Xbox
You are doing nothing wrong. The best thing to do, which you are doing, is to eliminate possible problems. Try a different cable, monitor etc until you narrow the problem down to a single component.
Aug 05, 2012 | Microsoft Xbox 360 Console
Sound but no pic
One of the cables which gives you the picture will be switched on HD instead of just tv there a little switch on the side on the the cable
Mar 23, 2009 | Microsoft Xbox 360 Console
Toshiba 57H82 Blurry Pic on HD inputs except Xbox 360
Probably your G-Hyper board. You will need expert servicer and should cost about 3-400.00
Craig www.classtorations.com
Jun 08, 2008 | Toshiba 57H82 57" Rear Projection...
Feb 13, 2008 | Televison & Video
No Sounds when connect XBOX 360 to HD port
you need to run the white & the red to the aud. input
Aug 27, 2007 | Sharp Aquos LC-42D62U 42 in. LCD HDTV
Televison & Video Logo
155 people viewed this question
Top Toshiba Televison & Video Experts
matt martin
matt martin
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
