Question about Universal Remote Control Televison & Video
I need a setup manual for the hype 4-in-1 universal remote control along with codes to a sanyo lcd tv
Will someone please tell me where I can get a manual for this Hype 4-in-1 remote control with codes to a Sanyo LCD TV. I need step by step instructions for this remote control.
    Top Expert:
  • Universal Re... Master
  • 76,204 Answers
Common set-up codes for Sanyo band TVs are; 0291,0299,0295,0297. Try these codes. For more information check this link. Setup procedure, and setup code list to many popular remote controls are given. Pull up older posts.
Posted on Dec 07, 2013
4 Suggested Answers
6ya staff
SOURCE:
Anonymous
SOURCE: programming a universal remote control for a tv
The code for a Sanyo TV set should be 100. Press and hold the TV button on the remote while entering the code. The light should blink 5 times if it was accepted, and then you can test to see if it worked.
Posted on Feb 10, 2008
Anonymous
  • 70 Answers
SOURCE: universal remote control nse urc22c-10
Found the manual for a URC22-10D (which should be very close) at http://www.remotecentral.com/cgi-bin/files/rcfiles.cgi?area=other&db=devices&br=nse&dv=universalremote&md=urc22d10a&kw=&st=&ar=&dt=&so=&pg=1&file=others/nse/urc22d10a-manual.zip
Posted on Jun 21, 2008
Anonymous
SOURCE: sanyo tv codes
The codes listed by Sanyo for my TV won't work in my star Choice remote.
I tried 017 021 039 056 057 058 and 140 as listed by Sanyo.
Any ideas?
Posted on Sep 19, 2008
Can you give me the codes for a sanyo tv for a universal remote
try this link...4 digit GE codes for TV sets including LCD, Plasma, and Panel TVs Brand Code SANSUI SANTECA SANYO SCOTCH 224 more rows
4 digit codes for TV sets including LCD, Plasma, and Panel TVs - GE ...
www.eliztech.com/remotes/ge-4digit-tv-codes.php codes for sanyo tv for universal remote Google Search
Dec 09, 2016 | Sanyo Televison & Video
What remote codes do we need to connect remote to Sanyo TV model 3264B 2008.
Mary, Universal remote codes for Sanyo TV model 3264B Check the attached links,instruction and guides containing 3 and/or 4 digit codes, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
http://codesforuniversalremotes.com/universal-remote-control-codes-sanyo-tvs
How to Set Up the Codes for Sanyo Television and Remote
4 digit codes for TV sets including LCD Plasma and Panel TVs GE universal...
Apr 26, 2016 | Sanyo Televison & Video
Need remote codes for sanyo tv
press the helpful button Step 1 Insert two AA batteries into the universal remote control if you haven't already done so and then turn on your Sanyo TV. Press and hold the "TV" button on the remote until it lights up.
Step 2 Input the following three-digit codes into your remote control one by one using the remote keypad: "004," "013," "049," "108," "110," "180" and "209." The TV will turn off when you enter the correct code for your particular Sanyo model.
Step 3 Press the "TV" button on the remote once more to confirm the code after you've identified the correct one. You can now use the universal remote to control your Sanyo TV.
http://www.remotecodelist.com/remotes/sanyo/sanyo_rmtu100.html
Jan 27, 2016 | Sanyo Televison & Video
I need a step by step instruction manual for a hype 4-in-1 remote that can be used to a sanyo 32 in tv
0048,0041,0044 are the common codes to user with Sanyo brand TVs. For more information check this link.Setup procedure, and setup code list to many popular remote controls are given.Pull up older posts. google.com/+GopakumarGopalan
Dec 06, 2013 | Sanyo DP32746 32 in. LCD Television
What is the code for a Sanyo DP26640 26" LCD TV
Hello
Remote code for Sanyo TV with Comcast Custom DVR-3 device universal remote control is
0154
1. Turn on a device (e.g., VCR or DVD
Player) and, if applicable, insert
media, (e.g., video cassette or disc).
NOTE: Please read steps 2 to 6 completely
before proceeding. Highlight or write
down the codes and device you wish to
program before moving on to step 2.
2. On the remote control, press a
device key once (i.e., AUX or TV).
NOTE: Use the AUX key to program
control of an Audio Amplifier or
Receiver, a DVD Player, a Home-
Theater-In-A-Box Device, a PVR (or
DVR), or a VCR.
3. Press and hold Setup until the
selected mode key blinks twice,
then release Setup.
4. Locate the code for your device in
Manufacturer's Codes on the back
of this user guide. Brands are listed
in alphabetical order with the
most popular codes listed first.
5. Enter the first four-digit code for
your device. If you perform this
procedure correctly, the selected
mode key will blink twice.
NOTE: If you enter an invalid code, the
selected mode key will display one long
blink and exit the programming mode.
Repeat steps 2 to 5 with a valid code.
6. Aim the remote control at your
device and press Power once. The
device should turn off. If it does
not respond, repeat steps 2 to 6,
trying each code listed for your
brand until you find one that
works. If it still does not work, try
Searching For Your Code.
NOTE: If the device does not have a
Power key, press the (Play) key
Apr 29, 2011 | Sanyo Televison & Video
I need the code to my sanyo tv
Hello
According ro RCA Codes for sanyo are detailed as
Code 004 for sanyo tv Code 048 for Sanyo TV Code 049 for Sanyo TV Code 073 for Sanyo TV Code 080 for Sanyo TV Code 107 for Sanyo TV Code 162 for Sanyo TV Code 169 for Sanyo TV Code 180 for Sanyo TV Code 196 for Sanyo TV
Just check with these codes according to the proceedings.
1. Manually turn on the TV.
2. Locate the enclosed TV Code List. Find
your brand of TV.
Note: If your brand is not listed, use one
of the Code Search methods to program
this remote control. (See section on
Code Search.)
3. Press and hold the CODE SEARCH key
until the indicator light illuminates.
Then release the CODE SEARCH key.
4. Press and release the TV key. The indicator
light blinks and then remains lit.
5. Use the number keys to enter the first
code listed for your brand. After you
enter a valid three-digit code, the
indicator light turns off.
Note: If you enter an invalid code, the
LED flashes rapidly for two seconds.
Start over at step 3.
6. Aim the remote at your TV and press
the ON•OFF key. If your TV turns off,
you have found the correct code.
7. Enter the code in the box provided on
this page for future reference.
8. If your TV doesn't turn off, repeat steps
3-6 above, entering the next code for
your brand.
Manual Code Search
1. Manually turn on the component you
want the remote to operate.
2. Press and hold the CODE SEARCH key
3. Press and release the component key
that corresponds to the component you
want the remote to operate (TV, VCR,
DVD, DBS•SAT, CABLE, AUDIO). The
indicator light blinks once and then
remains lit.
4. Aim the remote at the component. Press
the ON•OFF key continuously until the
component turns off.
Important: Because there are so many
codes, you may have to press the
ON•OFF key many times-possibly up
to 200 times.
5. When the component turns off, press
the ENTER key to store the code.
6. Use the Code Retrieval section on the
next page to identify the code for your
component for future reference.
OK
Feb 15, 2011 | RCA RCU600M Remote Control
I need the code to a sanyo tv
To control a Sanyo TV with a One for All URC-3021, follow these steps:
1) Turn on your TV.
2) On the remote, press the TV key once.
3) Press and hold SET until the LED blinks twice, then release SET.
4) Enter the four-digit code 0154.
The LED will blink twice.
If it does not blink twice, go back to step 2 and try the same code again.
5) Aim the remote at the TV and press POWER.
The device should turn off.
If it does not turn off, repeat steps 2 through 5 with the next code in the list.
I hope that helps.
Dec 04, 2009 | One For All URC-3021 Remote Control
Sanyo tv code for pansat remote
you can set up any like this
1. turn on what ever you want set up
2. press and hold set up tell light blinks or stays lit
3. push what you are trying to set up t.v. or dvd ect.
4. push power on/off tell it turns off
5. push enter when it turns off
Thank you for useing fixya please rate me
Feb 11, 2009 | Radio Shack (15-2147) Remote Control
Televison & Video Logo
235 people viewed this question
Top Universal Remote Control Televison & Video Experts
Christopher Stearns
Are you an Universal Remote Control Televison and Video Expert? Answer questions, earn points and help others
