We updated our pizza and topping prices and now RPE will not let us add toppings to pizzas. We can send a basic cheese pizza or specialty pizza through, but if we add toppings we get a pop-up window with the error: Value cannot be null Parameter name: key. In the pizza screen if we add a topping the price does not change in the upper right corner, but if we take the topping off once and re-add it a second time, the price adjusts on the screen in the upper right corner but will not go through and we get the pop-up error message. Help.
SOURCE: how do i change prices in restaurant pro express?
under manager, choose administrative, then inventory maintenance. This puts you where you set item pricing. You then need to locate the item. 3 ways to do this. Use the NEXT or PREVIUOS buttons to scroll thru entire inventory. Or if you know the item number, type it in the search box and hit ENTER. Or click the LOOKUP button and search for item on this screen and then hit SELECT.
If this helps, please give me a good rating. If you need further assistance with RPE, email me at [email protected] or call 814-797-5722 and ask for *****.
SOURCE: Syncing client with server - Restaurant Pro Express
Your getting a connection successful because your looking at the localhost. The server would be the network name of your server. And the password is case sensitive and is pcAmer1ca. (Note the number 1, not an i)
SOURCE: We just installed Restaurant Pro Express and we
Click on the link below to download the Restaurant Pro Express Guide Technical Support 845-920-0888 Technical Support (AOL Instant Messenger) Screen names posnow, posnow2 or posnow4
http://download2.pcamerica.com/12.0/rpe_getting_started_manual.pdf
You can also contact technical support at:
SOURCE: Is there a Restaurant Pro Express technical expert
I can setup floor plans, employees, & configure menus including modifiers (eg. how would you like that cooked?). I charge $12/hr to setup menus approx 8 hrs for a 2 page menu. Gina 773-807-2000
SOURCE: Installing restaurant pro express v12.5 help
If you are installing it for the first time, then you should have free tech support from PCAmerica. Take advantage of it and keep on them till it is working correctly. If you are out of warranty period, uninstall RPE from Control Panel after you record your license key number. Then delete any and all CRE folders and content from your hard drive. Empty Recycle bin and reboot. Then reinstall RPE.
[email protected]
Please return and give me a favorable rating if this helps or is of value to you.
Feel free to email me with more details if need be.
Testimonial: "I am still under warranty, I just purchased the program. Thanks for the reminder!"
The Web
Restaurant Store sells pizza cutter blades for a good price, although as the
pizza cutters themselves are not expensive, you might find it just easier to
buy a new one.
