Looking for two more plastic connectors to hook up two more speakers for my Sony home theater system Model # DAV-FR1 and connect to the back of my system. Help!!
SOURCE: Sony speaker connectors
Try this guy on eBay who is selling 2 varieties of Sony connectors, plus a ton of others
http://stores.ebay.com/BOGUE-ENGINEERING-GROUP
I'm about to pull the trigger on a set of his 4.2mm connectors for Sony HCD-HDX500 for $26
SOURCE: a friend of mine gave me her old Sony DAV-FR1 home
Sony's accessories page lists a couple of replacement connectors that may be what you need. They also offer a set of replacement wires.
SOURCE: Need replacement speaker cables for dav-hdx576wf
Since noone else gave you a good answer I will. I lost some cables to mine a while ago and found this awesome jerry rig solution; Go to radio shack, and ask for '14-16 gauge star ring terminal connectors' Should come in a pack of 10 and be about 2$. On the back of the unit where these connectors fit, there should be two prongs. You will need two star-rings for each connector slot. Wire up your connectors and crimp the ends LIGHTLY with a pair of pliers. The star-ring connector connected to the negative wire should be inserted to the left prong, (left if you are facing the back of the unit), and the right prong is the positive. If you did everything correctly, you should be able to make your own wires for sony stereo systems whenever you need to. Saved my ***, hope it did the same for you. Here is a link to what they look like. http://www.shopping.com/radio-shack-non-insulated-crimp-on-star-ring-terminals-10-pack/info
Register and download the manual for free at retrevo.com
http://www.retrevo.com/support/Sony-DAV-FR1-Home-Theater-Systems-manual/id/350bh741/t/2/
Page 51-ish
