Question about LeapFrog Leapster 2 Learning System
My leapster 2 just beeps twice and won't turn on
I've tried to look at all the possible fixes listed..I tried the eraser, I tried the batteries, I held the buttons, sometimes it gets stuck at the warning screen other times it just beeps loudly twice. I don't even know if its on or off
3 Related Answers
Anonymous
SOURCE: Leapster 2 will shut off right after the "important" screen
Are you using it with a game? Will it stay on if NO game cartridge is in & are U able to access & play Pre-installed games?
If so, it may be the cartridge is DIRTY. I discovered this with our Leapster 2. What works for us is getting a Q-TIP & RUBBING ALCOHOL, you want to saturate Q-tip with the rubbing alcohol & clean the CARTRIDGE (NOT the Hand held ).
You want to clean the computer chip @ the bottom by inserting Alcohol soaked Q-tip on each side of contact strip (the part that inserts into the hand held) & with the dry end of Q-tip go over it again, for more cleaning & to wipe up any EXCESS Alcohol. REPEAT this process until Q-TIP comes back CLEAN.
I was really surprised @ ALL the BLACK grime that came off cartridge.
I hope this helps.
Good Luck.
-The Johnson Family :-)
Posted on Jun 18, 2009
Anonymous
  • 235 Answers
SOURCE: Pink Leapster2 beeps and wont go pass warning page
One suggestion; Place in a Wal-Mart bag , drive to the store and go to customer service and ask for a refund(if you have the receipt) or ask for an exchange. Wal-Mart is good on that. Good luck!
Posted on Jul 09, 2009
Anonymous
SOURCE: Leapster 2 powers up to warning screen and then
Connect it via USB to your PC/laptop. It'll connect to the Leapster website and appear to update firmware. Once it is finished, it will let you know to disconnect. After that it should work. I had the same problem and did this, and now it's working fine.
Posted on Feb 10, 2010
How to fix Leapfrog Leapster 2 electronic board?
Leapster 2 Customer Support ' Online Help, FAQ, LeapFrog ...
www.leapfrog.com > Support > Products
LeapFrog EnterprisesVisit our customer support page for LeapFrog's Leapster 2 for help and answers to your product questions.Missing: electronic ‎board
How to fix Leapfrog Leapster 2 electronic board? - Fixya
www.fixya.com/support/t26040145-fix_leapfrog_leapster_2_electronic
35 mins ago - ... 2 electronic board? I know how to solder and basic principles ofelectronic parts. Know - LeapFrog Leapster 2 Learning System question.
LeapFrog LeapPad2 Explorer Troubleshooting - iFixit
https://www.ifixit.com/.../LeapFrog_LeapPad2_Explorer_Troublesh...
iFixitDrained/bad battery; Bad display; Water damage; Bad logic board ... Instructions toreplace the battery can be found at LeapFrog LeapPad2 Explorer Battery ...
Leapster 2 Quick Fix Tutorial - YouTube
? 3:02
https://www.youtube.com/watch?v=eQayGCjEdgo
Jan 22, 2009 - Uploaded by filterdragon
Tutorial on how to fix your child's Leapster 2. If your Leapster 2has a problem other than the screen not registering the stylis pen, please go to the Leaps... ... Ana E 1 year ago .... 2:34. leap frogleappad repair guide.
Jan 05, 2016 | LeapFrog Leapster 2 Learning System
Leapster explorer battries are charged but wont work when I switch it on
Try taking out the batteries and running an eraser over the contacts. One other thing plug it in with the batteries installed and try turning it on. After it comes on then unplug and see if works. Also make sure you are using the right kind of batteries. I had to use alkaline to get our to work.
Jul 05, 2014 | LeapFrog Leapster Explorer Learning...
My son's Leapster Explorer suddenly has no sound. If you hit the increase sound button, nothing happens. If you hit the decrease button you see the volume bar on the bottom of the page. Do you know...
I had same problem, just fixed it by a little hack. The volume up switch is broken.
1. Remove accessory door on bottom. 2. Remove all screws on back. 3. Open back cover.
Looking at the exposed board, there are 2 volume switches (back to back). Directly next the switches are four contacts: the upper 2 are for volume down, the lower 2 are for volume up.
4. Place the battery pack on the board and hold it down. 5. Press the power button to turn on the unit. 6. Use a small wire to jump the volume up contacts multiple times to change the volume to maximum (or desired level). 7. (Optional) Remove the volume buttons and throw away the rubber cushions to prevent the volume from changing. 8. Replace everything back in place.
Jun 14, 2011 | LeapFrog Leapster Explorer Learning Game...
When we inserted a new game cartridge (Pet Pals made for Leapster & Leapster 2) we get a question mark on the screen. We've changed the batteries and the old game cartridges are working fine. Please...
its not recognizing the game, contact is probably dirty. take an eraser and rub the contacts of the cartridge and get them super clean, blow out ALL the debris and that should fix it.
good luck!
Jan 29, 2011 | Leapster Learning System
We have a Leapster 2 less than 1 year old. It
We have the same problem and our leapster is only 2 days old.Do Touch Screen Calibration,it should help.I do it everytime for my son when he wants to play and it does help...But once u turn leapster off,u'll have to calibrate it again next time...
Just hold down hint button while turning on.When the Leapster menu screen appears,press the A button.Touch each of the crosshairs that appear with the stylus.restart unit. ..That what we do everytime.
Dec 03, 2009 | LeapFrog Leapster 2 Learning System
Dell Inspiron 531 (desktop) won?t turn on/boot
You've either got a bad motherboard or a bad processor (I'd lean to the motherboard being bad). I would honestly take this into a computer repair shop and have them check both.
Oct 22, 2009 | Dell Computers & Internet
Jul 09, 2009 | LeapFrog Leapster 2 Learning System
Leapster 2 showing white screen
I'm really not sure at this point -- there aren't to many things you can do with a leapster to fix the display....how old is it? Wondering if Leapster will do anything for you if it's too old to exchange at a store. Typically screens turn white if they need to be refreshed OR if they have overheated or been left in a car or a hot place -- because the lcd gets messed up in extreme heat. Wished I could help you more then that...but calling leapster sounds like your only option right now..unless exchanging at the store is possible.
Jun 26, 2009 | LeapFrog Leapster Electronic Book:...
Leapster 2 unit turns on, warning msg re. seizures and flashing lights stays for a few seconds then shuts off. Has new batteries. my daughter has the same problem with hers it turns on and brings up an...
We have 3 Leapsters. The old green model and 2 newer models. Our green one started doing that not long after having it. But it still works and if it shuts off, then we just turn it back on again. When I called up c/s for Leapster, they sort of make it difficult to return. And then I was not promised a new one, but it could be new or refurbished. I let it go. Now w/ the 2 new models, I believe this has happened. I've questioned if my kid's are accidentally hitting the power button. I have seen the green one power off before. I purchased the $10 plug in's. So worth it. No more batteries. And we haven't had any issues. So perhaps it is the batteries. Call up Leapster though and see what they have to say. Good luck! :)
May 26, 2009 | LeapFrog Leapster 2 Learning System
Leapster won't turn on
Had the same problem. I could randomly make it turn on by some bazzarre combination of pushing buttons. Now won't do anything. Call Leapster 800 #, and thought I was getting a bunch of b.s. from a "tech" person, however IT IMMEDIATELY RESOLVED THIS PROBLEM. Remove the battery pack and batteries. Take a pencil eraser and rub/clean the contact point where each battery goes in on the tray (except the coil sides). Reinstall the batt's back in the trey. Use the eraser to do the same thing to the outside contact points on the outside edge of the tray as well as on the Leapster itself where the tray goes. Finally reinstall the the battery tray, and BINGO ! Crazy....I would have lost a bet on this "fix".
Nov 20, 2008 | LeapFrog Leapster Electronic Book:...
LeapFrog Leapster 2 Learning System Logo
225 people viewed this question
Top LeapFrog Toys Experts
Marvin
Marvin
Lawrence Oravetz
Are you a LeapFrog Toy Expert? Answer questions, earn points and help others
