This morning I could not get the lid of the coffee maker to open. Any suggestions?
SOURCE: Krups Caffe Bistro 867 Expresso & Coffee Maker INSTRUCTIONS
http://www.krupsusa.com/All+Products/Coffee+Machines/Espresso+coffee+machines/Products/867+Bistro/867+Bistro.htm
SOURCE: FME2 Coffee Maker
From page 9 of the manual:
Setting and Adjusting the Clock
• The machine must be “off“.
• Press and hold the prog button (o) for 3 seconds: the hours will blink “88 _ _“.
• Adjust the hours in steps by pressing the h/min button (n).
• Press the prog button : the minutes will blink“ XX 88“.
• Adjust the minutes in steps by pressing the h/min button.
• Confirm the setting by pressing the prog button.
Normal
0
false
false
false
MicrosoftInternetExplorer4
/* Style Definitions */
table.MsoNormalTable
{mso-style-name:"Table Normal";
mso-tstyle-rowband-size:0;
mso-tstyle-colband-size:0;
mso-style-noshow:yes;
mso-style-parent:"";
mso-padding-alt:0in 5.4pt 0in 5.4pt;
mso-para-margin:0in;
mso-para-margin-bottom:.0001pt;
mso-pagination:widow-orphan;
font-size:10.0pt;
font-family:"Times New Roman";
mso-ansi-language:#0400;
mso-fareast-language:#0400;
mso-bidi-language:#0400;}
http://www.krupsusa.com/Consumer+Services/Product+Support/Results/Manuals/ResultManuals.htm?SelectedService=Manuals&SelectedGuIDService={FA4AA2D9-9799-4F8F-8136-8FEB029407FD}&SelectedProdRef=FME2
SOURCE: my Krups coffee maker is leaking some coffee onto the counter
no normal fix it requires worshop inetervention to replace the seal
SOURCE: A Krups KM7005 coffee maker/grinder doesn't heat or drip water .
Mine had the same problem ... all the lights are on, grinding works fine, but no heat on the plate, and no dripping of water.
After a weekend on the workbench, I mastered this machine. The KM7005 has 2 x MicroTemp G4 thermal cutoff (TCO) fuses which interrupt the Live line, for overheat protection. Mine didn't overheat per se, but the TCO blew anyway. Not reset-able ... need to be replaced with a soldering iron. To date, I have helped 13 people on this site fix this exact problem.
I'll be happy to advise you to fix this, or fix it for you. Write me at [email protected].
SOURCE: Dear Sir!
Check on the Krups site:
http://www.krups.com/Consumer+Services/Product+Support/Manuals/Use+Intructions.htm
