SOURCE: how to erase parental control code
I finally found out how to reset the V-chip password on this princess DT1350-P Tv. All you have to do is turn the TV on and turn to a channel that doesn't prompt the V-chip password (even if it's snowy) and hold down the volume (down -) button on the main unit while holding down the number "0" on the remote control. It might take a few tries, and you might need to change the TV channel for some reason but if done correctly, either the TV will turn off, or the menu screen will pop up and ask if you want to set the vchip password, either way you should be able to watch your TV now! :)
Hi Jessica
There are two methods to reset the Parental Control on a PlayStation 2, the Quick Method and the Easy Method.
The Quick Method to Reset Parental Control
If you do not know the Parental Control password on your Ps2, try the known defaults of 1111 and 7444.
The Easy Method to Reset Parental Control
