Question about Ace Hardware PowerGlide 18V Trigger Cordless Drill/Driver
Cummins cordless drills 18 v
I am having problems with a cummins drill/driver it is cordless. my problem is the batteries will not hold a charge. can i find replacement batteries or should i just toss the drill?
Posted by Charlotte Whaley on
I've got this old drill/screwdriver that won't take/hold a charge, I see you may have a solution for that; you responded that you could help . . . . what do I need to do to get it charged again?
cordless drill or screwdriver that won't charge usually has a bad set of rechargeable batteries so these need to be replaced, if replacements are available.
Mar 15, 2016 | Drills
18volt cordless drill battery charger will not charge batteries
Fist you should check that if there is problem with your battery or charger. Do you store your batteries in right way when you don't use them?
You can come here (Power Tool Batteries Drill Batteries Replacement) and find if there is batteries or chargers for you.
Mar 26, 2014 | Drills
No power on a fully charged batery why?
Users have reported problems with the charger and battery life on this drill. If possible verify the charger is working by swapping it with another or using a voltmeter on the plug.
If it is, the battery has failed and will not hold a charge. It is uneconomical to replace it.
Nov 22, 2013 | Craftsman 14.4 volt Cordless Drill/Driver...
My 7.2 v drill won't charge
If your drill is old and has had a lot of use, it may be that the battery has had a full life and just needs to be replaced. Batteries will only take so many charges and then will quit holding a charge.
Feb 27, 2011 | Black & Decker & Cordless Drill
Battery will not hold a charge
If the battery is one year old, it is shot. I have about 20 batteries under the bench and about 5 cordless drills , saws, lights, you name it , I won't buy anymore. I have a bunch of them, the batteries don't last. It is cheaper to buy a new kit with new batteries than to replace the batteries. No more.
Oct 24, 2010 | Ryobi 18v 38" One+ Cordless Drill P205 18...
I have a 14.4 volt cordless drill that when I try to charge the battery the red light goes from a slow to a rapid blinking after about 60 seconds. The battery does not hold a charge regardless of the...
One thing I,ve found with cordless tool batteries is that if they're completely dead, the charger won't recognize them. Try hooking a known good battery with a charge up to the problem battery, terminal for terminal, with small jumpers. Leave it hooked up for a minute, maybe a minute and a half. this should be sufficient to provide just enough charge to bring the battery up to the "threshold level" required for the charger to recognize it. Then, simply charge the battery in the normal way. If this doesn't work, you may need new batteries, or a new charger. Hope this helps you.
Aug 24, 2010 | Dewalt DC920KA Heavy Duty Xrp 18V Cordless...
I have a 12v xrp cordless drill. in the past 6 months i have purchase 3 new batteries. none will hold a charge. what is the problem.
You may want to try a different charger base. Any way you can borrow one so you don't have to purchase first?
If for some reason the charger isn't working well, you may be getting a partial charge and only that.
You may even want to rent a cordless just to try charging your own battery on a different base.
before you buy.
Nov 03, 2009 | Dewalt DC920KA Heavy Duty Xrp 18V Cordless...
Ryobi HP 961
look at the cost of new batteries,sometimes for a few more dollars its better to just buy new cordless.some brands are very expensive on the replacement batteries.
Sep 07, 2009 | Drills
Won't charge fully
If your warranty has expired, you're best off buying a new drill. Replacing batteries will quickly add up to the cost of a new drill.
I know they cost a lot more, but, if you want something that will last a lot longer, look at a Milwaukee, DeWalt, Makita, Bosch, Hitachi for your replacement. Milwaukee actually guarantees their LiIon batteries will last 1,000 charges or longer.
May 24, 2009 | Black & Decker 14.4v Cordless Lithium...
Ace Hardware PowerGlide 18V Trigger Cordless Drill/Driver Logo
597 people viewed this question
Top Ace Hardware Drills Experts
Marvin
Marvin
Tom Chichester
Pieter Vleeshouwers
Pieter Vleeshouwers
Are you an Ace Hardware Drill Expert? Answer questions, earn points and help others
