Question about GE 46GW 948 46" Rear Projection Television
How to ajust bulbs
How to inline picture
Posted by Dennis Westley on
How to reroute the drivibg belt or fan belt
Hi,just inline the crankshaft to the top dead centre marks,then check that the camshaft marks line up,if they dont line up then turn the crankshaft pully again untill the camshaft marks line up,slacken the timeing belt pully adjuster take belt off and replace with new one,tighten the pully adjuster back up,now put a spanner on the crakshaft pully and turn clockwise untill the top dead centre marks and the camshaft marks inline if they dont then slacken the ajusting pully inline marks again and try again,if marks do inline ok then you are ready to start the car.
hope this helps good luck.
Feb 25, 2015 | Cars & Trucks
My Sony Trinatron has suddenly displayed a dark screen on all channels. You can see the picture but looks like it's nightime. I've tried ajusting the brightness but no result.
does the TV bring out sound even as the screen display is dark?
Problem should be from the TV lamp/bulb. When a TV bulb/lamp is dying, it makes the pictire on the screen become dark and very hard to see.
Have the lamp replaced and hopefully, your screen should be perfect as before.
Let me know if you need directions in replacing the lamp, even though it is very simple replace.
Yours sincerely.
Elect_Comp.
May 14, 2011 | Sony FD Trinitron WEGA KV-20FS120 20" TV
When a low light or night scene is on the picture is barely visible.
open the back of your tv and there will be a small box hanging from the crt cage those little knobs control focus and brightness you can set your set in front on 50 percent or "default" and then ajust the brightness of each crt bulb behind the tv.
Mar 11, 2011 | GE 46GW947 46" Rear Projection Television
Cant ajust picture to fill out screen, 3 inches
try this restore to defualt values monitor and cpu
Jul 10, 2009 | Acer Computers & Internet
Primer bulb doesn't pump gas
Does the primer bulb pop back out or does it come out slowly? Is the inline hose in good shape or has a crack where it can **** air in? Did you check to see if the diaphgram in the carb is pliable or is it paper-like and needs replaced. Or your carb could be stopped up.
Only one problem..I can't think of any weedtrimmer that has an inline fuel filter. They are usually located in the gas tank.
Jun 24, 2009 | Troy Bilt Tb70ss Gas Trimmer
Older gas range not heating up enough
Pull the knob off of the oven control and see if their is an ajustment. If the ajustment doesn't work then change the thermostat bulb. It goes for the oven to the back of the oven control know
Dec 21, 2008 | Ovens
Head light bulb adjustment need to be level
if you didnt play with the ajustment it should be the same if not the light is not install the right way move the bulb it should work thanks pierre
Jun 24, 2008 | 2005 Nissan Altima
Nec mt 1000
go to menu- go to setting -go to colour move slider to right hand direction befor you change the lamp -take care that some vga cabel(((cabel between pc and projector make this fault).then you have to change this cabel and try.
Mar 09, 2008 | NEC MultiSync MT830 Multimedia Projector
Open Questions:
See all GE 46GW 948 46" Rear Projection Television Questions
GE 46GW 948 46" Rear Projection Television Logo
Top GE Televison & Video Experts
matt martin
matt martin
Are you a GE Televison and Video Expert? Answer questions, earn points and help others
