Question about eMachines W3115 PC Desktop
Bios emachine emachine w3115 bios, no bios file updated version or prior version available online or at their support's website!!! Weird....
Posted by Rej Jal on
Lars Olsson
    Brigadier General:
  • eMachines Master
  • 3,400 Answers
1 Related Answer
Carl Beigle
SOURCE: how do i free up space on my emachine w3115
defrag periodically, and dump your temp internet files on a regular basis.
Posted on Feb 23, 2012
I need a free antivirus for my computer
Free antivirus is only available with microsoft security essential
you can download from microsofts official website
Feb 25, 2014 | eMachines W3115 PC Desktop
Can not find emachine w3115 bios download
There's no reason to flash your BIOS they rarely add enhancements to BIOS's usually just bug fixes. Plus it's dangerous to flash it unless you know exactly what you are doing if you half flash something then it's toast flash is either all or nothing.
Dec 06, 2013 | eMachines W3115 PC Desktop
How do i free up space on my emachine w3115
Feb 23, 2012 | eMachines W3115 PC Desktop
I have four sata ports inside my emachine desktop and my bios says not installed
If the SATA ports are showing not installed on the BIOS then it can be due to either older BIOS version or the Ports are not detected. I recommend to update the BIOS from the emachines website, please follow the link below:
htttp:\\support.emachines.com
Select the computer model and download the BIOS
It should take care of the issue.
Thanks and regards,
Jitha.G.J
Dec 20, 2011 | E-Machines eMachines Desktop PC
I am try to upgrade the memory in my W3115 from
The bios has nothing to do with memory,
What memory did you have installed, what moder;llkl'j wqpwrl #
Feb 08, 2010 | E-Machines eMachines Desktop PC
I have the same problem with my T3120 emachine.
could be a 'gray market' machine! i've run into this before- basically 'your motherboard/bios' doesn't exist- good luck! boot up should show what your bios version is, look for that, rather than your motherboard version!
'my computer'- 'properties'- should have your bios info on it. use that info to find updated 'flash', if it's available.
good luck!
Oct 08, 2009 | E-Machines eMachines Desktop PC
Need to locate safe AMI BIOS update file for eTower 500is
you should restart and press F2 (on most pcs) to opent Setup. from there find the name and version of your bios. then go to your current bios providers website and download the flash update. it should be listed under the support tab. you may have to search. hope this helps. please rate me and thanks for choosing enterprise computing solutions.
Sep 30, 2009 | E-Machines eMachines Desktop PC
Deleted sound card
There is no way you can delete a sound card. But I guess you are referring to the sound card driver shown in Device Manager. It's not a problem, just open Device Manager from Control Panel -> System -> Device and then click on a the icon Check for Device Changes to ask WinXP to locate the driver automatically. If it does not, just insert the Sound Card driver CD into the CD drive and start the installation manually.
Jul 13, 2009 | E-Machines eMachines Refurbished EMA...
Reformatting E-machine desktop computer W3115
Insert the CD to the CD ROM. Set the bios setup to boot using the CD-Rom. Space bar while booting up. If you got the setup press F8, choose NTFS to format the drive. Then go on with the Installation.
Mar 10, 2009 | E-Machines eMachines Desktop PC
eMachines W3115  PC Desktop Logo
165 people viewed this question
Top eMachines Computers & Internet Experts
Lee Hodgson
Lee Hodgson
efs_perpends
efs_perpends
Michael Thomas
Michael Thomas
Are you an eMachines Computer and Internet Expert? Answer questions, earn points and help others
