SOURCE: Dishwasher will not drain
if you have a garbage disposal make sure to take the plug out.
or the motor sylinoid is burn out.
SOURCE: Kenmore Dishwasher won't drain
If you opened and closed the door and it started, that sounds like a bad, door switch in the console.
But you did hear a hum sound when it tryed to drain, it could be the drain solenoid, or the motor/pump assembly.
Take off the bottom access and look at the solenoid when it starts to drain, the piston in the solenoid should move freely, up and down with the white drain flapper that it connects to.
Also check for bad wiring connections at the power junction box where the power hooks up to it under the dishwasher, i have seen the wire nuts either come loose or burn off due to loose connections.
SOURCE: Kenmore Model 587.15103800 dishwasher won't drain
dip water out take pump apart remove debris look for broken blades if so install pump kit thumbs up
SOURCE: My Sears Kenmore Elite will not drain
Pump might be restricted, with food particles, check it pump assembly from inside the cabinet, the drain hose also could be plugged, and finallly make sure that the impeller of the pump itself is working
SOURCE: dishwasher will not drain water
Drain out is done via the pump out motor. Is the pump out motor working? Check by deternining with a AC voltmeter to see if supply voltage is across the terminals in pump out mode. If voltage is present and motor does not spin - the motor is open circuit and must be replaced. Remove the 2 clamps and the 2 electrical push on terminals with the MAINS voltage disconnected. Is the outlet pipe not blocked or obstructed ?
