My screen is black "floppy diskette seek failure"
The floppy disk or drive is damaged, or if your trying to boot your computer and you have a floppy in the drive that is not bootable. It will try and boot from floppy first then cd then hard drive usually but floppy's are stupid and only return an error and then stops. Remove the floppy disk and boot
SOURCE: Floppy Diskette Seek Failure on boot up
Hello there:
This is a setting in the bios , so what you are going to have to do
is boot into bios and under the boot section and check to see if the floppy drive is a option that is part of the boot sequense if it is change it so that is not part of the boot sequense than go under the periphial section and check to see if it is showing up there as a removable device if so change it or disable it all together since you do not have a floppy drive ok
and this should take care of he problem
I hope that this is very helpful for you
Best regards Michael
SOURCE: floppy diskette seek failure
F2 Scroll down to "Drives" and open the menu. choose "Diskette Drive" and turn it "Off".
try to go to bios set up..then change the boot order..in the boot tab,,change the "first boot" label with hard disk..then it wont seek for floppy again..
SOURCE: Diskette Drive 0 Seek Failure This seems to be a
You are missing the OS.
If you have the restore CD's, use them to restore your Dell to original state, or you can order a set from Dell.
If you do not have a restore CD's you can also boot with a Windows CD and install the OS but you will have to go to the Dell website and download the drivers for your model.
I hope this helped.
Good luck and have a pleasent day.
SOURCE: "Floppy Diskette seek Failure Strike F1 key to
maybe the floppy disk drive is defective or maybe the IDE cable is deffective, or maybe the cable on the floppy drive is not properly inserted , try to replace IDE cable of the floppy drive if still the symptoms happens replace the floppy drive
