I am installing the receiver in a business with only one pair of +/- speaker wires, for mono signal. Can I get that from the RX-4109? I hooked red & black up to stereo left, since left is usually mono, but got no sound. Do I need a second speaker to make it work?
SOURCE: sherwood rx-4109 power shuts off
The output transformers may-be gone
looking at +$50 AUS
for just the parts
or a licensed service
for about $150 AUS
SOURCE: No sorround sound coming out of speakers out both left and right
I just repaired one for slow start .recapped the whole power supply board and now starts first go.I will check it out next week and post what I found
SOURCE: Sherwood RX-4109 receiver has no
Maybe a shorted right speaker took out the other channel. Does it turn on now? Generally speaking, an amp protects itself from heat, shorts, overloads and operator exuberance by refusing to turn on or stay on. Overloads can be from excessive periods of high output or marginally low impedance loading by the speakers; and shorts would be wiring issues or a speaker blowing up. You should be able to feel if it's hot. WHY is it overheating? Make sure it has sufficient ventilation on all sides and that vent holes are not blocked by dust balls. Ensure the fan (if equipped) is running as designed (some only operate on demand). Clean dust and debris from it. If the amp comes back on after cooling, you're lucky. They only have so many self-protection cycles in their lives so continuously resetting or cycling their power without addressing the cause can do more harm than good. If it protects immediately on a cool power up you should disconnect the speaker connections and try it 'naked'. If it comes up then diagnose which lead(s) are shorted. If it does not come up the problem is internal and should be left to an experienced and competent hands-on tech.
You can test the speaker for open or short by touching a small battery to the speaker wires. It should make static or click sounds. If not, it's dead. If it sparks and akes no sound it's shorted and dangerous to any amp.
SOURCE: I have a sherwood RX
By design, yes for one pair of 6-ohm speakers used at a time; depends on the sub for the second BUT there is no way to control its volume at the Sherwood.
SOURCE: Hello, I have a Sherwood RX-5502
The statement on page 7 might allow enough wiggle room for a single pair of 4-ohm speakers used alone. Procede with caution and don't try to blow the walls down with them. Monitor for excessive heat or strain and if it clips or self-protects back off.
http://www.sherwoodusa.com/pdf/RX-5502(A).pdf
Unlike the budget stereo receivers now flooding the entry-level price points at dealers across the country, the Sherwood RX-4109 is designed and built in-house with the same quality and attention to detail we have been bringing to our audio gear for the last 50 years.
With 105 Watts RMS per channel, phono section, binding posts, a versatile remote control and switching for two pairs of loudspeakers, the only thing that bespeaks the word "budget" about the RX-4109 is its modest cost.
MSRP 179.95
