Question edited into written English with punctuation.
The lens isn't black, the viewfinder is black. Connect it to a television or computer and see if playback and live recording is working. In that way you know the optics and the electronics are working. The viewfinder is a small LCD display screen with a magnifying glass in front of it. Take it to your local camera shop, they will know someone that still repairs these camcorders.
I was hoping to find a free PDF manual as I wondered if there is a switch or a setting to turn OFF the viewfinder?
Interesting that it has worked so long. You might want to consider a better camera since even the cheapest digital video camera today will have better video than a VHS-C camcorder. With the VHS tape it only recorded analog signals and each copy of the tape would degrade. Most cellphones today will take video that is orders of magnitude better than a VHS-C unit . . .
On these camcorders the "RCA" video jack is a switching jack. This is so the cam will record from an ext video source instead of live video. Try exercising this switching lack by repeatedly plugging in and unplugging an rca video cord. This may be a solution to your problem.
Knowledge Article
C116445
There is no picture or a black screen appears in the viewfinder or LCD when attempting to record.
Follow
this procedure to troubleshoot if there is no picture or a black screen
NOTES:
Because
each of these steps represents a possible solution to this issue, check
the viewfinder or LCD status after completing each step.
It
may be necessary to refer to the operating instructions provided with
the camcorder for information on how to perform a task on your specific
model.
Ensure the lens cap on the front of the camcorder has been removed.
Ensure a fully-charged battery is inserted in the camcorder.
Ensure the STANDBY/LOCK switch is set to the STANDBY position.
Turn on the camcorder and set it to the CAMERA mode.
Look to see if an image can be seen in the viewfinder or LCD.
IMPORTANT:
Some camcorders have both a viewfinder and LCD. To conserve power, the
viewfinder and LCD will not display at the same time. To use the
viewfinder, the LCD must be closed.
If the issue is not resolved, reset the camcorder to factory specifications.
NOTE: If the issue is still unresolved after completing the troubleshootin
Thats an oldie but still a goodie.. this camcorder was made by Hitachi for RCA and its doubtfull that theres any parts
available for it. You are probably gonna have to look around for someone with old camcorders laying around and swap out the veiwfinder . these units are also famous for the belts to go bad in them. if you take this unit to a servicer they probably have a flat rate as I've seen online under camcorder repairs unless you think you can do it your self?? Good Luck
PS If I get a good look at the veiwfinder and if theres a plug or is it hard wired I may have one as I got several camcorders around the place i use for opsolete parts.
