Question about Sanyo DS27910 27" TV
Menu arrows wont move
Hi, I have had my TV for a little under a year, I cant use the menu at all. The only way i can even get it on the screen is to use a remote. But no matter what remote it is the up and down channel and volume keys dont work. I need to add my CABLE channels to the roster. Please help ASAP
  • 93 Answers
In your case, i'm sure the your memory in tv is def or your microprocessor is also def.
Posted on Oct 13, 2007
6ya staff
SOURCE:
How to turn off child lock without remote control jvc lt-32sh6
Press the "Menu" button to set the lock code for your JVC TV. A padlock icon will appear on the menu display.
Press "Zero" to access the lock code function then use the left and right arrows to select the four-digit number for your code. Use the up and down arrows to move to the next area of the display.
Select the up or down arrow to finish your lock code then use the left or right arrow to save your lock code settings and exit the menu. You can return to this display if you forget your four-digit lock code and set another code.
Write your four-digit lock code down and keep it in a safe, private area.
Select the locked TV channel you desire to watch or want to unlock. A message will appear on the display requesting you to enter your lock code to unlock the channel.
Unlock your JVC TV by entering your lock code on the 10-key pad. The message "Invalid Lock Code!" will appear on the screen if you enter the wrong lock code.
OR
Select "TV" from the menu then select "V-Chip" from the drop-down list on the screen. "Please Input Password" will appear on the screen.
Enter your four-digit password by selecting numbers on the 10-pad that appears on the V-Chip menu display or your remote control. Create a new password if you forget it by unplugging your TV power cord from the outlet then reconnect the power cord. This procedure resets your password to "0000." Enter four numbers for your new password using the keypad on the screen or your remote and select the arrow to advance to the next number. Press "OK" on your remote or select "OK" on the screen to set your new password.
Unlock a TV rating or TV channel by selecting "MPAA" or "TVPG" from the V-Chip menu. Use the up or down arrows to select the locked rating then select "OK" on the display or press the "OK" button on your remote control to unlock it. The MPAA represents the U.S. Motion Picture Association of America rating system, such as "NC-17," meaning not intended for viewers 17 years or younger.
Nov 01, 2012 | Televison & Video
How do you get rid of military time on the LG start-up screen?
Hello
Enter the Menu and come to Manual Clock Setup Screen.
Press the MENU button and then use UP/DOWN button to select the TIME menu.
Press the Right Arrow button and then use UP/DOWN button to select Manual
Clock
Press the Right Arrow button and then use Left arrow/Right arrow button to select either the year,
date, or time option. Once selected, use the UP/DOWN button to set the year,
date, and time options.
Press EXIT button to return to TV viewing or press MENU button to
return to the previous menu.
On the time option, you can select itt to 12Hour or 24Hour format. OK.
May 01, 2011 | LG 42LC2D 42 in. LCD HDTV
Cant turn on set and remote wont work, how can I reset tv and remote to work after our grandchildren locked the fromt buttons ans remote?
hello it sound like the key lock has been activated
The TV can be set up so that it can only be operated with
the remote control.
This feature can be used to prevent unauthorized viewing.
This TV is programmed to remember which option it was
last set to even if you turn the TV off.
Press the MENU button on the remote
control, then use the UP/DOWN arrow
button to select the Special menu.
Press the RIGHT arrow button to activate
the Special menu.
Use the UP/DOWN arrow button to
choose Key lock, then press the RIGHT
arrow button.
Use the UP/DOWN arrow button to select
On or Off.
Press EXIT button to save and return to
TV viewing or press the MENU button to
save and return to the previous menu.
the remote control.
Language
Main Source
PIP Source
Captions
Caption/Text
ARC
Key lock G
Auto Convergence
Auto Move
F Back Next G
SETUP
VIIDEO
AUDIIO
TIIME
LOCK
SPECIIAL
On
Off
With the KEY LOCK ON, the display
'KEY LOCK' appears on the screen if
any button on the front panel is
pressed while viewing the TV.
which option it was last set to
even if you turn the TV off. good luck
regards
shaun
Dec 12, 2010 | Zenith R56W36 56" Rear Projection...
Need to know to set the convergence
Have you tried going to the service menu?
Do this by holding "MENU" on the TV set while it is on, then pressing "Menu" on the remote. You may have to do this a couple times for the menu to appear.
There should be a option on the appearing screen for Convergence, which has more options the the standard menu. To work this under the "9" setting for convergence, each of the + on the screen is the corresponding button the the TV remote (3 if top right, 5 is center). Use your volume or arrow keys then to move the selected + in the desired direction.
Jun 17, 2010 | Zenith R40W46 40" Rear Projection...
The televion has started showing a blue and yellow douwble vision on the bottom of the screen?
Use the [TV/Video] button to switch which color you are aligning, trying to align Red Green and Blue so they overlap, making white.
Feb 21, 2010 | Zenith R40W46 40" Rear Projection...
Purple verticle lines on flat screen Samsung TV
How does the tv menue look. Does it cover the stripes or do the stripes affect the menue. if menu ok main board if menu affected bad panel. If under 1 years it is still under Samsung warr. Even if older than 1 year contact Samsung to see if they will cover repair.
Aug 31, 2009 | Samsung LN-S4692D 46 in. LCD HDTV
Samsung LE26R73BDX 26INCH - LOSS OF DIGITAL SERVICE
Solution that worked for me:
Beware: Although the process should be safe, it technically voids your warranty.
Enter the service menu:
1 - turn of tv with remote
2 - press and release in the following order on the remote: Info, Menu, Mute. Make sure remote is pointing at the tv
3 - turn on the tv from the remote
4 - you will see the service menu. using the down arrow on the remote select the Reset option. Using the right arrow button at this point will do a hard reset.
5 - Wait a few seconds, turn TV on
6 - you will have to rescan analogue and digital channel but it should be working now.
Dec 28, 2007 | Samsung LE26R73BDX 26 in. HD-Ready LCD...
Ink cartrige wont work
press menu then start mono then arrow up button 4 times.
machine will be in mainténance mode. press the arrow up button until 7 is displayed. press menu. press arrow up til 6 then press menu. press arrow up til 3 Dispaly shows powerp_all press start mono. machine runs a power purge. after that press arrorw up til 0 press menu press arrow up til 9 machine will print test sheet. In case you dont have a good result do the power purge again. If you dont get a good result after 3 times purging, the printhead is clogged and cant be fixed anymore!
to leave the maintenance mode press arrow up til 9 then menu then arrow up til 9.
Nov 05, 2007 | Brother DCP-110C All-In-One InkJet Printer
Tuning a Channel
why did it get the highest raiting?? it doesent even say a solution
Sep 23, 2007 | Philips 30PW633R 32" TV
HELP!!!
Go back in the menu, find (input source) or (tuner) then click the cursor right side of the menu button or the left to move the (TV) to (CATV), after you bring it up then move cursor arrow up or down to page (AUTOPROGRAM) then tap the cursor arrow right of the menu button to start the CATV channels to be found , be sure you have the cable connected to the TV. Once the channels have been found, tap (EXIT) or (STATUS) button on remote to get out of the menu and close the page, or just turn set off and back on again.
May 29, 2007 | Emerson EWC19T3 19 in. TV/VCR/DVD Combo
Sanyo DS27910 27" TV Logo
93 people viewed this question
Top Sanyo Televison & Video Experts
 Grubhead
Grubhead
Jerry Greenberg
Jerry Greenberg
Are you a Sanyo Televison and Video Expert? Answer questions, earn points and help others
