Question about Samsung LNT4069F TV
Power light blinking red, keeps poping up what the tv can do on the screen ,can't control any funtions
Posted by michael somma on
    Top Expert:
  • Samsung Master
  • 76,407 Answers
How many times this standby/power light blinks at one time switch ON?Count it carefully.These blinks are fault indication, and known as blinking codes.From the number of blinks occur at one time switch ON; you can get an idea about the faulty circuit stage inside the TV.This will make repair easy. For more information, check the link http://electronicshelponline.blogspot.com/
Posted on Dec 07, 2013
1 Related Answer
SOURCE: standby red diode stays
this is a problem with the switch mode power supply unit,check for the components not functioning in this unit and replace
Posted on Sep 22, 2011
Some time ago, I was watching TV, then, all of sudden, the TV screen has gone, just like 'blank'. The main power (red light) keeps on blinking. Normally, it is just on, not blinking. TV doesn't respond at...
These blinks (flashes) are fault indication. By the number of blinks occur at one time switch ON, you can vet an idea about the faulty circuit stage inside the TV. Count the blinks occur at one time switch ON, carefully. Do it once again, and make sure about the number of blinks. If the flashes are continious, non-stop, the main system control IC should be suspected. If you wish to get more details, check the site linked here. It has blinking codes detail to many brand TVs. Pull up older posts. http://electronicshelponline.blogspot.com/
Dec 24, 2013 | Bush 5693D 24" TV
Screen blank
Sounds like a cap or fuse has blown in the set, you will need to take the back cover of and have a look, check on the power board for any blown caps, you will notice them straight away if one has poped, also check any fuses that may have blown they will also need to be replaced.
Feb 18, 2010 | Sony FD Trinitron WEGA KV-36FS120 36" TV
I have power but it will not turn on. unplugged from power cord overnight then plugged into wall worked fine until i shut it off again, now it keeps blinking the delay light
go to turn tv on,hear a poping noise,once then tv standby lite blinks 3 times repeatily but no picture or audio.can you help me out with this thank you
Feb 14, 2010 | Sony FD Trinitron WEGA KV-36HS510 36" TV
Universal remote - program digital converter box and Roku?
if you still have your remotes you can program the buttons for each funtion.
1. Hold down P until the red light blinks
twice.
2. Press 9 7 5. The red light blinks twice.
3. Press the device key that corresponds with
the desired device's remote (TV, CBL/SAT,
DVD, VCR or AUD).
4. Press the desired learning key. The red light blinks rapidly.
5. Place the device's remote control head-to-head
(about 2 inches apart) with the
11
Gamer Remote.
6. On the device's remote control, hold down the key to be learned until the red light on the Gamer Remote blinks twice. If the red light does not blink twice, repeat Steps 1- 5.
7. To lock in learned functions on the Gamer Remote, hold down P until the red light blinks twice.
8. To test a learned function, press the learned key on the Gamer Remote and use the function as usual.
Jan 14, 2010 | Radio Shack (15-2147) Remote Control
Tv keeps clicking red light blinking but doesnt come on first it was fifteen minutes then thirty now an hour and it i still not on?
the red light blinks due to a problem in the power supply or deflection circuit, this usually happens when one or two components start changing specified value or just entirely go out. Some samsung tvs do have replaceable boards but you still need to pinpoint the problem to a certain circuit board, either deflection or power board. It may be worth it to call a service tech and describe the problem to get a good idea on the repair cost.
Oct 13, 2009 | Samsung PCK5315RX TV
Model TC-32LX700 Power indicator light on from is
Problem is caused by voltage irregularity. Pulled plug for an hour and then plugged it back in. TV reset and it works fine. If this does not work it needs a TV technician.
Sep 14, 2009 | Panasonic TC-32LX700 Television
Screen went dark
Ur video ic inverter board is dead.
U need a new one.
Aug 25, 2009 | Televison & Video
Toshiba dlp 46 inch red light keeps blinking
42 inch Toshiba DLP. Was watching a movie and the screen went dark. The red light started to flash and kept flashing. any ideas
Jun 26, 2008 | Toshiba 46H84 46" Rear Projection...
Open Questions:
What can I buy / replace to fix my tv? I have a 4 year old Samsung LCD (LNT4069FX/XAA.) A few months ago the image started ghosting, or flickering and repeating itself multiple times down the screen, accompanied by a slight discoloration and / or darkening. At first I could "fix" the problem by gently applying pressure around the frame, or by swiveling the TV on it's stand back and forth. Once the problem was "fixed" the picture was perfect, and would remain that way until the TV was turned off, where I would have to start all over again the next time it was turned on (usually at least a few hours if not over night in between.) Eventually the turning / applying pressure did nothing. The TV would however "fix" itself after approximately 10 minutes. Again, resulting in a perfect picture and lasting until the TV was turned off. Over the course of 2 or 3 weeks, it would take more time upon start up for the problem to fix itself, 15 minutes, 20 minutes, until eventually no amount of time would solve the problem. It is worth mentioning that this occurs on any inputs, and even with no inputs - it is definitely the TV, not a cable or a source problem. I happened upon a similar complaint on your site, where the advice given was to replace the LCD converter, which I did, and the problem is still apparent. Do you have any other solutions that I may try? I would much rather fix this TV instead of buying a new one. Thank you for your time! - Jim D (the article I mentioned is here...) http://www.fixya.com/support/t8380218-samsung_hdtv_ln_t5271f_approx_4_yrs
May 06, 2012 | Samsung LNT4069F TV
See all Samsung LNT4069F TV Questions
Samsung LNT4069F TV Logo
214 people viewed this question
Muntejaya Ginting
Muntejaya Ginting
Todd Hill
Todd Hill
