Maytag MZD2667HE Side by Side Refrigerator Logo
T
TimJ Posted on Dec 06, 2013
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Can't change dispenser selector
The Crush option is currently selected and I can't change it to Water or Cube. I can push the Water selector maybe 10 times and it will switch for one second to Water and then go back to Crush.
MAX POWER
Level 2:
Sergeant:
  • Expert 419 Answers
  • Posted on Dec 06, 2013
 MAX POWER
Expert
Level 2:
Sergeant:
Answers
419
Questions
0
Helped
113286
Points
758
Seems defective control panel in front of fridge
  • TimJ
    TimJ Dec 06, 2013
    Is that difficult to replace? And would that be the name of the replacement part I would need to order?
4 Related Answers
A
Anonymous
  • Posted on Oct 29, 2007
SOURCE: Ice Maker -cube selection
job well done
Michael Anderson
  • 172 Answers
  • Posted on Sep 30, 2008
SOURCE: water/ice dispenser activates at will, selector panel locks up
Hi jrupich,
There is only two things that can cause this problem. One would be the dispencer control board. Part #61003425
The other thing is a stuck or shorted dispencer switch
part #61005520
Since you say that you have already replaced the control, I would have to go with the switch, but in rare cases the new board installed in the dispencer can also be faulty. Some appliance techs will even sell you a used one and tell you it is new. You have to trust your repairman. Good luck to you and I hope this will FixYa. please dont forget to rate me.
Mike Anderson (Owner)
Anderson Appliance
(865)945-3808
Anonymous
  • 700 Answers
  • Posted on Apr 03, 2009
SOURCE: Change water filter for a maytag plus refrigerator
press the light switch button inside of the refrigerator five times.
Anonymous
  • 1734 Answers
  • Posted on Aug 31, 2009
SOURCE: I have a Maytag Plus
Normally you just need to hit the unlock button in for 10 seconds.
If this not works, here is what you need to do -
Note: If dispenser is active for more than five
minutes, an automatic lock out sensor will shut
down power to dispenser area.
Dispenser Lock/Unlock
The Dispenser Lock and Unlock affects all keypad functions.
To Lock Dispenser:
  • Press and hold the Lock/Unlock button for three
seconds. A green indicator light above the button will
illuminate when the dispenser is locked.
To Unlock Dispenser:
  • Hold the Lock/Unlock button for three seconds. The
green indicator light above will go out
Otherwise your refrigerator has a preset shut down program that protects the dispenser from flooding your kitchen. The control will shut down and will NOT reset when unplugged. The control needs to be reprogrammed. This mode was triggered by drawing out water for too long of a period of time. Call a Maytag service dealer.
Ice dispenser
sounds like u may need to replace the switch
Ice cube stuck on crush
remove the ice bin,there must be a chunk of ice blocking the cubed dispenser chute of the dispenser and channeling all ice thru the chopper chute,run hot water thru it to melt any chunks blocking the cube chute,then dry it and let it get cold before filling with new ice or you will have the same issue again
2helpful
The buttons that select water, crush or cube do not function. I can get crush or cubed ice but the water button does not work. I have tried turning off at the mains and starting again but still there is a...
remove the front cover off this selector panel(if equipped) and replace the interface board in behind here as the little switches are bad and theres no fix to these boards
Hi i have a double door samsung fridge and when i place dispensable ice on cube i still get crushed ice in addition is there any way to increase the speed at which water comes out the dispenser
There is likely a faulty solenoid which switches the ice dispenser between "crush" and "cube" mode.
The water pressure at the water dispenser is proportional to the supply line water pressure. Unless there is a restriction in the supply line or the dispenser line, the only way to increase the water flow is to increase the supply line water pressure -- not an easy proposition.
More info, let me know.
Charlie
2answers
How do I turn off the change filter light on my fridge? It has a button for water,cube, crush, light, and lock.
Hard to say without model and make of refrigerator but the owners manual should say which one will do this. mine has a button dedicated to this. If all else fails you can unplug the refrigerator or turn off the breaker to reset until a manual can be found.
GC3SHEx300 ice dispencer does not dispense cube or crush ice. Water comes out, lights work. it is not deactivated.
Ice crusher stuck on crush mode can't swith back to cube
is it push button or do you manually have to turn dial from crush to cube. I have push button and had this problem once before.(LG side by side) I turned off at power (remove cord from wall) and removed ice tray all together. save some ice for testing. Check to see if crush part was clean. Put ice back in container and put back together and turn back on at power point. See if you can have cubed now.
1helpful
My Frigidaire Electrolux refrigerator ice dispenser is dispensing chrushed ice regardless of whether the ''crush'' or ''cube'' option is selected. The icemaker is working. How to diagnose the problem? The...
Open the freezer door. Pull the ice bin OUT and then push it back IN until it locks in place. They will "jump the track" at times,causing crushed ice regardless of the settings. Look under the ice bin. You will see a metal rod it goes inside a yoke in the back of the freezer. Make sure it is inside,not under or over the yoke.
Dispensing problems
Check that the crush mechanism is not jammed with ice. That could prevent it from disengaging.
Ice dispenser is stuck in crush mode
Carriage that moves ice bucket rod up is frozen.It's right by the auger drive mote on the left- square hole. Remove bucket and try to free it with your finger. If no luck take hair dryer until you can move it up and down.
Top Maytag Refrigerators Experts
vince
Johnny 1000
Jesse Walters
Jesse Walters
Are you a Maytag Refrigerator Expert? Answer questions, earn points and help others
