Question about Juicers
Cannot switch on - Juicers
Posted by wansatu on
Why will jucier not switch on?
The juicer could be defective as received.
Jul 06, 2014 | Philips HR1861 700 Watts Juicer
Omega 8003 does not turn on. Could it be the switch that is defective?
Never oil a power switch. Sounds like a defective switch and if others have the same problem go to the manufacturer website and look for a possible recall or solution.
May 18, 2014 | Omega Juicers
Where is the safety Switch in the Jack Lalanne juicer express?
The safety switch is on the bottom base where the pulp collection bin goes. If you look on the pulp collection bin there is a small tab that when assembled right deactivates the safety switch. The main arm that holds the top container where you put the produce in is also a safety mechanism that when not in place the machine will not turn on.
Sep 08, 2013 | Jack Lalanne Power Juicer 250 Watts
I have Jack Lalanne Power Juicer 250 Watts and it will switch on. I have changed the fuse, but to no effect. Any suggestion?
The stainless bar should be on the correct slots on top of the juicer. It has a safety switch on those bars. Smell the motor from under the juicer, it should not smell like burnt. Press hard on the switch, it might be loose.
Oct 24, 2009 | Jack Lalanne Power Juicer 250 Watts
Santos 28 wont switch on
Problem with internal micro switch,no power suply or locking handle not activating safety switch
Jul 08, 2009 | Matfer SANTOS Juicer
I have a Jack la lane power juicer and the power switch did not work. So I dis-assembled the motor and power switch and found 2 springs. Now I want to assemble it back but did not know where these 2...
The stainles bar has 2 springs on each end. Maybe this is the springs that you have. It is a power safety switch wherein there is no power if the bar is not seated in the right place.
Jul 06, 2009 | Jack Lalanne Power Juicer 250 Watts
Motor not running
The stainless bar has a safety cut off switch at both ends. You have to put it back the same way to make the outer switch work.
Jun 17, 2009 | Jack Lalanne Power Juicer 250 Watts
Brand new breville juicer vfj005 cow design,it wont work,no book
In all juicers there are hidden interlock switches called interlocks for ur protection. Put all the parts properly, so that these switches sense them. then it should work.
[email protected]
Mar 05, 2009 | Breville Juicers
Juicer will not run
Make sure the stainless bar running across the top is snug on the left and right groove. It has a shut off switch when not installed properly.
Jan 08, 2009 | Jack Lalanne Power Juicer (Stainless...
Juicers Logo
105 people viewed this question
Top Juicers Experts
Tom Chichester
ray gallant
Bill Boyd
Are you a Juicer Expert? Answer questions, earn points and help others
