Question about Zanussi FJS1225W Front Load Washer
Zanussi front load washer door seal
I would like to chance my Zanussi's door seal.   There is a kind of mould area I was not able to clean it.  Well if you give me an idea how I can clean it there is nothing wron with the seal apart from the mould.
Thank you
Ergun
Posted by robin58 on
  • Anonymous Mar 13, 2014
    Afresh Grit Grabber is recommended for cleaning the seal. I use the Afresh tablet once a month to clean the machine, but the Girt Grabbers for the seal are ridiculously expensive. Is it safe to use Clorox or Lysol cleaning cloths instead for cleaning the seal?
    I use the Afresh tablet once a month to clean the washer. Afresh Grit Grabber is recommended for cleaning the seal, but the product is ridiculously expensive. Is it safe for the seal to use Clorox or Lysol Wipes instead?
prem mathew
    President:
  • 1,294 Answers
Keeping the door open after your wash would help in keeping the interior dry. Do not push the door shut, just leave slightly open. Only before you begin your wash, check to see your cat is not inside.
Posted on Jan 02, 2008
Mold door seal
If you want the door seal replaced any local domestic engineer will be able to do this. The mould is caused by excess detergent, constant washing at low temperatures, keeping the door closed when the machine is not in use. If you want to stop the mould reappearing once the seal has been replaced you need to carry out regular service washes (boil wash with a descaler/sanitiser). Use the correct amount of detergent for the amount of washing to be done and the hardness of the water in your area. Give the door seal a quick wipe after you use it and try and keep the door slighlty ajar when not in use.
Oct 18, 2013 | Siemens WFXD5200UC Front Load Washer
Black mould
this is the fatal flaw of front load washers, see this complaint over and over, use bleach to clean it or Tilex mold and mildew remover, make sure the hole that drains the seal is clean.
May 13, 2010 | Zanussi ZWF1440 Front Load Washer
How to fit a Zanussi fridge door seal
You mean you have a door gasket. A good, step-by-step article on this pesky concept of "panel-screw" gasket installation is found on this handy page:
http://yourhandymanzone.com/Your_Handyman_Zone_How_To_Pages_Appliance_Zone_Refrigerator_Install_A_Refrigerator_Door_Gasket.htm
This should help!
Brad
May 21, 2009 | Refrigerators
Mouldy door seal on hotpoint ultima 14 months old
hi, has the seal been replaced?if not use an old tooth brush and clean it with tooth paste it will clean off the mould, if the seal has been replaced check around the rim for a drain holle it may have been fitted wrong, some dont have drain holes hope this helps
Feb 05, 2009 | Hotpoint Ultima WF860 Front Load Washer
My zanussi washing m/c is leaking from the front of the drum
Could be door boot seal or indeed the drum having a hole in it, the seal is simple to do drum is not worth while.....Although a good grade Silicone would seal it...
Jan 08, 2018 | Zanussi FLA1101W Front Load Washer
Zanussi jetsystem 1400 door seal
IF YOU REMOVE THE SEAL UNLESS YOU ARE AN ENGINEER YOU WILL FIND IT EXTREMELY DIFFICULT TO REFIT IT, TO CLEAN OUT THE SLUDGE USE A PLASTIC SCOURING PAD LIKE THE ONES USED FOR CLEANING DISHES. IFTHE SEAL IS BLACK THIS CANNOT BE CLEANED IT IS A CHEMICAL REACTION TO DETERGENTS ETC BUT IS NOT HARMFUL TO ITEMS BEING WASHED HOPE THIS WILL HELP.
Oct 09, 2008 | Zanussi ZWF1440 Front Load Washer
LG Intellowasher wm-14220 FD
I had this problem, and it seems to be because the machine doesn't have the chance to dry out, so mould collects in the door. When the washing machine isn't being used, I simply leave the door slightly open - the washing machine dries and the black mould issue just about eliminated.
Aug 04, 2008 | Washing Machines
Zanussi fjs1225w nasty smell around door seal and inside machine
Are yo;u susing front loading detergent? My smell went away when i switched.
May 14, 2008 | Zanussi FJS1225W Front Load Washer
Zanussi FJS1225W Front Load Washer Logo
449 people viewed this question
Top Zanussi Washing Machines Experts
peter gittos
peter gittos
Marvin
Marvin
Fundi mnoma
Level 1 Expert
Are you a Zanussi Washing Machine Expert? Answer questions, earn points and help others
