Question about Alpine CDE-9843 CD Player
How do i attach my blackberry to my alpine CDE-111R
I have recently got an Alpine CDE-111R but cant work out how to attach my blackberry via bluetooth to it.
Posted by Lee Hillon on
5 Related Answers
simplemitch
Mitch
  • 752 Answers
SOURCE: Alpine CDE-9843
Page 16 of the manual:
http://vault.alpine-usa.com/products/documents/CDE-9841,%2043,%2045%20OM.PDF
Setting Time
1 In the Clock priority mode, press and hold
TITLE for at least 2 seconds while the time is
displayed.
The time indication will blink.
2 Turn the Rotary encoder (CDE-9845/CDE-9843
only) or press
4 and 3 (CDE-9841 only) to adjust
the hours while the time indication is blinking.
3 When the hour has been adjusted, press the
Rotary encoder (CDE-9845/CDE-9843 only) or
press MODE (CDE-9841 only).
4 Turn the Rotary encoder (CDE-9845/CDE-9843
only) or press
the minutes while the time indication is blinking.
The time is automatically set 5 seconds after the minute
adjustment. The time can also be manually set by
pressing the Rotary encoder (CDE-9845/CDE-9843 only)
or press MODE (CDE-9841 only).
• To synchronize the clock to another clock/watch or radio time
announcement, press and hold the Rotary encoder (CDE-9845/
CDE-9843 only) or press and hold MODE (CDE-9841 only) for at
least 2 seconds after setting the “hour.” Minutes will reset to 00. If
the display shows over “30” minutes when you do this, the time
will advance one hour.
Posted on Aug 05, 2008
Eagleeyes
Mark Waller
  • 199 Answers
SOURCE: Alpine CDE-7859 **** Preseting the radio stations?****
http://www.alpine-electronics.co.uk/index.php?id=915&L=&manualsearch=CDM-7859RB
User Guide can be downloaded from here
Mark
Posted on Nov 17, 2008
Anonymous
  • 74 Answers
SOURCE: Alpine CDE 7853 removal
remove the face and then the trim ring for face you should see 2 little pins on either side of the radio slide them up and it should slide right out
Posted on Nov 28, 2008
etirbynnor
Ronny Brite
  • 655 Answers
SOURCE: Alpine CDE-102 w/usb port: will not
Hello desoren,
The receiver may not be set to recognize MP3 files.
Press and hold "sound setup" until the unit enters setup mode. Rotate the volume knob to "play mode" and press "enter". Check that the setting is CD/MP3 (not CD/MA), or rotate the volume knob to change the setting to CD/MP3 and press enter again. Press and hold "sound setup" again until the unit exits sound setup.
If the files are still not recognized, I'd try using a different USB drive, a different computer to write the MP3's, and/or a different application to download or rip the original music content.
Hope this helps.
Posted on Sep 23, 2009
etirbynnor
Ronny Brite
  • 655 Answers
SOURCE: i am getting a DC error on my alpine cde-102 head
Hello christo12385,
The DC error is most likely caused by a shorted or grounded speaker wire. Check all speaker wires, correct the problem, and then go into the sound setup settings and reset the POWER IC to ON.
Hope this helps.
Posted on Sep 25, 2009
I have an Alpine CDE-SXM145BT car stereo. that will not play Bluetooth devices.
Have you had the battery removed at any time before this happened or been jump started ?
Apr 09, 2017 | Alpine Car Audio & Video
Why I have no sound on Alpine CDE-111R. After six years appeared an option which it never appeared before, "BT AUDIO".After that is no sound anymore
Seems that you activated Bluetooth audio for playing music from a Bluetooth device. If you google alpine cde111 manual you will get a link to the owners manual which gives step by step instructions on how to disable Bluetooth audio
Aug 12, 2016 | Alpine Car Audio & Video
Alpine firmware update
Can't be compatible, because the plug is the 30 pol. not the lightening plug.
First make sure the cable is compatible, then check if you Alpine can work with it.
Doesn't have the Alpine blue tooth already?
Jul 17, 2014 | Alpine Bnib - Cde-111r Cd/mp3/usb Tuner
My Alpine CDE-W235BT bluetooth has stopped working after a failed update. How do I fix it?
Sounds to me like the firmware is damaged, try flashing it with another firmware, or maybe updating it with the same update but successfully if possible.
Aug 01, 2013 | Car Audio & Video
Alpine CDE-7858 external input?
yes there is an adapter cable made for this search alpine aux adapter on ebay they run aprox $30 it will plug into cable on back and give you 2 rca inputs to use for ipod and such...
Nov 23, 2008 | Alpine CDE-7858 CD Player
Alpine cde 9846
which "sub level" are you talking about? dB? or gain? either one, you must open your am and check the variable resistors ("volume" knobs) with a multimeter
Dec 16, 2007 | Alpine CDE-9846 CD/MP3 Car Stereo
Alpine CDE 9881
You must have a faceplate from that exact model, no others will work. You can try to contact Alpine for a replacement. If it is any consolation, someone has a useless faceplate, because it won't work with anything else, either. Try running an ad in your local lost & found column, you just might get lucky, especially if you offer a reward.
Jul 28, 2007 | Alpine CDE-9881 CD Player
Alpine CDE-9843 CD Player Logo
29 people viewed this question
Top Alpine Car Audio & Video Experts
Robert Salgado
Robert Salgado
Jeffrey Turcotte
Jeffrey Turcotte
Marvin
Marvin
Are you an Alpine Car Audio and Video Expert? Answer questions, earn points and help others
