SOURCE: Toshiba satellite A205-S5847 booting problem
Check your GraphicCard. Have you tried downgrading to XP and can you tell if you facing same problem?
SOURCE: My Laptop is Toshiba Satellite A350 series
If you have a Toshiba Recovery CD you may be able to install XP, otherwise :-
You need a Windows XP installation CD together with the installation Product code.
To install Windows XP insert the CD in the laptop and boot up with the CD and follow the screen instructions.
You can download any/all the Windows XP device drivers for your model laptop from the Toshiba WEB site from their download page.
Make sure you enter the model of your laptop so you can get the correct drivers.
Use this link :-.
http://www.csd.toshiba.com/cgi-bin/tais/support/jsp/home.jsp#
SOURCE: toshiba satellite wont start up, operating system not found
Hello my friend, regarding on your problem since you bought that laptop 2 weeks ago i presume that your laptop is currently under warranty so to avoid warranty void kindly return it to the supplier or the shop where you buy that laptop in order to ensure that they will accomudate your laptop cause it is under warranty. Also let them check and fix the problem cause the problem of that laptop found inside meaning the BUS or connector fromo your motherboard to your hard drive which is why it cannot found the Operating System cause it does not locate and detect your hard drive where you stored you Operating System.
Hope this will able to solve your problem using this recommendation. If you need more assistance just reply to this post.
If you find this recommendation/solution able to help your problem solved please rate this solution.
Thank you and Godbless.
SOURCE: WEBCAM DRIVER OPEN FAIL. Toshiba M300 satellite
Go here and download the driver utility for your webcam.
http://www.csd.toshiba.com/cgi-bin/tais/support/jsp/modelContent.jsp?ct=DL&os=&category=&moid=2228766&rpn=PSMD8U&modelFilter=M300-ST3402&selCategory=3&selFamily=1073768663
