sounds like a safety switch problem. but maybe you can help me i have the same model do you have a lot of jerking when you start off of turn with yours?
Hello & Welcome to FixYa If the pilot is clean and still won't light then the problem is with the safety valve that won't open and so needs replacement. Please get back to me if you have any other questions. Kevin
have you tried shifting with the car stopped not running does it shift easy or hard sometimes the syncro inside the trans gets worn or the shifter fork could be bent damaged usually a trans shop or specialist can help you work on it because its a big job tom pull out the trans and tear it apart but if you want to do it yourself its possible
If you have a tom tom from the GO models
they hace a reset button you can press with a pin were the mount fits.
When you plug in the charger the green light should come on to say it is chargeing.
Try the car adapter to charge the tom tom
i do not know if you have changed the voice on the preferences, if not on main menu 1 page tap change preferences,go to page 4 tap change voice, the computer voices will be 1st ,then tap the one you want then select , hope that helps
