How to listen to music from your lap top via yamaha audio and video receivers
SOURCE: Yahama HTR-5730
Here's the manual; http://www.yamaha.ca/av/PDFs/Manuals/2004_receivers/HTR5730E.asp See if you find a solution in there - if not please ask again and we will see what we can do :)
SOURCE: Connecting a Yamaha VX7 Subwoofer on my Yamaha HTR 5730 AV Receiver
Hello srqwrk,
You can connect the VX7 to the 5730 using an RCA Y cable like the one shown in the picture below. You get your one connection for the receiver and 2 for the VX7. These are available at any electronics store. Remember that the cable should be long enough to go from the receiver to where subwoofer will be placed.
Hope this helps. Let me know.
cancerags
SOURCE: No component video output
Hope this helps
The Yamaha HTR-6030 offers two types of video monitor output: Component and Composite. You may need to connect both types to your television as the HTR-6030 does not have composite to component video conversion. In other words, to view your VCR on your TV, you need to use the composite video monitor connection. However, for a DVD player or other source that has component video connections, use the component video monitor output to your TV. If your TV has both types, you simply switch between the two with your TV remote to access the proper video monitor output signal from the HTR-6030.
SOURCE: Playstation 3 audio connection into Yamaha HTR-6040 AV Receiver
Solved problem with Yamaha HTR-6040 AV Receiver. My daughter had inadvertently changed the program to "Direct Stereo" mode which allows sources to bypass the decoders and DSP processors so you can listen to 2-Channel PCM and Analog sources. Nothing to decode digital audio in this setting!
SOURCE: Is it possible to play my ipod nano through my Receiver?
If it doesn't have a jack made for plugging Mp3 players into it like the new car stereo's do than you just have to go buy an FM transmitter that is made for Mp3 players. It will play through one of your low FM frequency's on your receiver. You can generally pick one up for around $20
