Question about Motorola CP185 (16 Channels) Two Way Radio
Jan 25, 2015 | Radio Communications
Feb 07, 2014 | Cobra LI3900-2DXVP (14 Channels) 2-Way...
Jan 26, 2014 | Cobra FRS 250 (14 Channels) 2-Way Radio
Dec 15, 2013 | Radio Communications
Nov 24, 2013 | Motorola Walkie Talkie 2-Way Radio
Nov 10, 2013 | Cobra Radio Communications
Apr 18, 2012 | Computers & Internet
To transmit to a radio that has QT noise filtering turned on:
1. Select the same channel and Interference Eliminator Code as the other radio.
2. Press 'musical note' button to send a call tone. This allows your voice to pass through the QT
noise filter on the receiving radio.
3. Press the PTT and speak normally.
Note: If you skip step 2, the beginning of your message may not be heard on
For a 30-second period, starting after the last transmission, all transmissions
received on the selected channel and code will pass through the QT noise filter.
Also, your QT filtering will NOT work if you are in scan mode.
http://www.giantintl.com/RadioPDFs/Outdated%20Manuals/T56XX_57XX_User_Manual_E.pdf
Best regards.
Aug 06, 2011 | Motorola Talkabout T5720 (7 Channels)...
Nov 12, 2010 | Motorola XTN UHF Two-Way Radio Series
Jan 20, 2007 | Motorola XV2100 (1 Channel) 2-Way Radio
163 people viewed this question
