Question about Reddy Heater-170,000 BTU Kerosene Deluxe
I need a manual or picture of how to fix my ignator
Model RC165Ct
Posted by Russell on
daryl bunkley
    New Friend:
Looking for the same diagram
Posted on Jan 09, 2014
Installed a new ignation switch with the keys that don`t have chips. Motor turns but won`t crank. Also keys won`t come out of the ignation unless thr ignation is unplugged.
It's not going to start without receiving the right code from the chipped keys. You've only swapped out half the anti-theft system. The rest is in the software. No way to get past that. Fix it right or you'll be walkin'
Jul 11, 2017 | Cars & Trucks
Put in new ignator will not lite
Did you follow installation instructions on the ignitor? The pilot light may have gone out. Try turning the gas off to the dryer for a couple minutes and then following the pilot light lighting instructions for the valve assembly. Youtube has many good videos on this as well.
Dec 01, 2014 | Maytag Dryers
INJECTORS WONT OPEN FOR MY FORD EXPLORER 2002
need to service the injectores or better replace them
Nov 07, 2017 | 2002 Ford Explorer
My ignation fuse is blown. i'll replace new one it blown again. what is the coz and how to fix it?
The short answer is something is pulling too much amperage thru the circuit.
You would need to find out what is in that circuit then check for shorts to ground.
Feb 16, 2013 | Cars & Trucks
Alert/Alarm for key/headlights no longer sounds
The owners manual should help shed some light on this problem. The car may be somewhat programable for the alerts and warning systems. You may also need to lubricate the door button that senses the door is open and closed. Good luck.
Dec 10, 2012 | 2003 Honda Civic
Where is the distributor cap on a 1998 kia sportage?
the Kia does not have a distributor, let alone a distributor cap, the engine is equiped with a ignation coil at each cylinder, there is a crankshaft and camshaft sensor that send signels to the onboard computer system then the computer sends the signals to the ignation ignator it then sends the signals to the coils at each cylinder. a much better system then a distributor.
Jan 04, 2012 | Kia Sportage Cars & Trucks
Hi my ignation is not working because the fuse inside the ignation box is burnt what is amp of the fuse so i can replace if,where can get the fuse from.thank you
That is not that hard to fix and you can easily buy the parts yourselfonline...
Here is a tip that will help you with the online buying...
How to Buy Appliance Parts Online
Here is one site that I recommendhttp://ping.fm/zJDAM
heatman101
Aug 26, 2011 | Smeg 23 in. SE64 Gas Cooktop
Maytag stove MGS5770ADB - Burners will not light - ignators
The spark module should be behind the rear panel of the range, or behind the bottom drawer, mounted on the interior back wall. If you go to searspartsdirect.com, the part is listed as item number 22 under the "Gas Controls" heading. The part number is 74004283. Just type in your model number and follow the links on the next page. There are helpful drawings to assist you. If in doubt, trace the wires from the the surface igniters and they all will lead back to the spark module. I hope this information helps you. Let me know if you need further assistance.
Jun 21, 2008 | Maytag MGS5770 Gas Kitchen Range
Oven Ignation would not Stop flickering after ignation
This is usually due to the "brain" of the stove going bad, better known as the control module... not an expensive fix if you can find the part and due it yourself... you can locate it iether in the back right corner when you lift the stove top or it's under an access panel below your broiler drawer depending on model.
Jan 15, 2008 | Brown Stove Works TM110-3 Gas Kitchen...
Reddy Heater-170,000 BTU Kerosene Deluxe Logo
53 people viewed this question
Top Reddy Heating & Cooling Experts
Paul Carew
Marvin
Marvin
Fahr Quad
Are you a Reddy Heating and Cooling Expert? Answer questions, earn points and help others
