Question about Delta Saws
Need wiring diagram for 230 v for delta table saw cat. #36-451
Wanting to change it from 120 volt to 230 volt and need wiring diagram to make change
Posted by Daniel Mattson on
Robert L Kershaw
    Scholar:
    Night Owl:
    An expert who has answered 10 or more questions between 12 midnight and 6am on the same day.
  • 72 Answers
Is the motor designed for dual voltages? The manual does not have a wiring diagram. I assume the motor lable diagram is faded or missing.
Dual voltage motors contain two sets of winding. Each set is rated for the lower voltage. To operate the motor on the higher voltage the windings must be connected in series. AND, they must be connected in the same direction. I use a variac to apply 30-40 VAC to the coils in various combinations, then measure the open lead voltage to determine the proper connections. This test should be performed by a licensed electrician.
Posted on Jun 26, 2014
5 Related Answers
Anonymous
  • 12 Answers
SOURCE: on/off switch table saw
It sounds like you are wiring the switch wrong. Give me the model # and I will look for a wiring diagram for you.
Posted on Feb 25, 2009
efs_perpends
efs_perpends
  • 1997 Answers
SOURCE: I need a wiring diagram for a Delta xl-10 table saw.
Unfortunately, the manual for the XL-10 saw is no longer available online. Here is a link to the parts list and diagram.
If that is not helpful, please consult a qualified electrician, who should be able to guide you in the wiring of the switch and motor for that saw.
Without access to the schematic, I'm afraid the best solution to your wiring question is for some capable electrician to take a look at your saw in person.
Posted on Mar 31, 2009
A Miller
  • 8404 Answers
SOURCE: i need the wiring diagram for my 10 table saw
Im guessing ... the motor is 110 volt AC (AC dont care if it is coming or going) ... find the two terminals in the motor and hook the wires back up. If it HAPPENS to be incorrect, the saw will run poorly or the overload will trip.
I wouldnt be afraid to use this method on my craftsman table saw.
Posted on Nov 03, 2009
rowdy45176
David Ford
  • 2176 Answers
SOURCE: 10'' delta table saw manual
you might try Dewaltservicenet.com but you will need the model number and you might have to put the dash in between to get it to list the model. Let me know if you need more assistance and if you do I would also need this information.
Posted on Dec 08, 2009
VtToolMan
Mark
  • 704 Answers
SOURCE: I need a manual for a delta saw
Here's a free manual you can download that provides an exploded view of all the parts and a complete listing of each part in the saw.
http://www.ereplacementparts.com/images/dewalt/34-670_Type_2.pdf
Here's a link to the Delta-Porter Cable website where you can also get a free manual via download. Just select which version you have, either Type 1 or Type 2 on the bottom of the page and download that for free
http://www.dewaltservicenet.com/SearchResults.aspx?q=34-670
Hope you find this Very Helpful and best regards!
Posted on Dec 10, 2009
1helpful
Model 36-979. Where can I get a wiring diagram for the power switch?
images for Delta Table Saws wiring diagram for power ...
Replacing a Table Saw Power Box and Switch. Rocket ...
? 7:45
https://www.youtube.com/watch?v=8A25b9BjkmY
Feb 12, 2014 - Uploaded by AdventuresInDIY
See how an in the way power box on a 10 inch Delta table sawwas switched out ... Would you happen to have a wiring diagramfor your saw.
Oct 28, 2015 • Delta Saws
Where can i buy a 230 volt 120 watt wire in touch dimmer for a table lamp
Roger -
Are you sure you need a 230 volt dimmer in your table lamp? If this is being used in the US or Canada, it is more likely to be a 120 volt lamp. I think you will have trouble finding a 230 volt dimmer.
Need to purchase delta 36-979 dado head table insert for 10' table saw
Use an appropriate pc of mdf that is same thickness of throat plate already installed. Use a router to flush trim to that throat plate. Now, insert and hold down with clamps and scrap panel. Raise Dado head ,while running, enough to do the job. This completes a zero clearance throat plate. No need to buy!
Changing volage on table saw
usually on the back of the plate where the wires go into the motor there is a wiring diagram for changing the voltage. UNPLUG saw first before removing the plate. Let me know if you need more assistance and I will try and help
Hello, I have 33-990 10" Radial Saw and loss the conection of voltage 230 115 switc selector , they have 4 wires to conect, I need the order. Thanks.
If you are connecting up to three phase the black wire is the neutral, Connect the other three and if the motor runs the wrong way change over two of the wires - not the neutral.
2answers
I inherited an older Delta 10 inch table saw. While cutting lumber the blade slows down and stops. The wood is not binding the blade. With power off the blades and motor turn freely. Does the motor...
Two easy possibilities are that the blade is dull or that the wire is too small. The wire is likely to be a problem if you are using an extension cord. You could move the saw near to an outlet that you know to be wired with 12 gage wire (not 14). Or you could buy as short as possible 12 gage extension cord. If being underwired is the problem, you will notice that the motor comes up to speed much faster when wired adequately. You might also buy a cheap new blade to rule out the dull blade problem. If neither of these fixes the problem, then the motor has become "weak" because it has overheated just enough to cause some minor shorts between the windings. (If the shorts are major it won't turn at all and will trip a breaker.) In this case the motor can be rewound, but it will probably be cheaper and easier to just replace the motor.
Good luck, Al K
3helpful
How do I align the saw blade with the saw table I have a 10 inch Delta Contractor's saw that is about 10 years old. The blade is not straignt with the miter slot. [email protected]
The Blade Arbor is held to the bottom of the table with mounting screws and stop/adjusting screws. Loosen the mounting screw and adjust the stop screws to make Blade true with miter slot.
3helpful
On/off switch table saw
Nov 02, 2008 • Saws
Saws Logo
Top Delta Saws Experts
Ronny Bennett Sr.
Ronny Bennett Sr.
Jay Finke
Jay Finke
Abdul Rasheed
Are you a Delta Saw Expert? Answer questions, earn points and help others
