Sigma Powers Inc Rural King 6,500 Watt Electric Start Portable Generator 6500E Logo
A
Anonymous Posted on Dec 05, 2013
Need a sigma 6500e assembly diagram - Sigma Powers Inc Rural King 6,500 Watt Electric Start Portable Generator 6500E
Carl E Thompson
Level 1:
New Friend:
  • Contributor 1 Answer
  • Posted on Mar 01, 2014
Carl E Thompson
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
707
Points
I just purchased a Sigma 6500E generator, there was no instruction manual with it. Did get in stalled, but couldn't find out where to connect the battery cable, also there was nothing about the engine at all. Does the battery get charged when the generator is running ?
I would hope that information is available for this unit. thank you
Hello All, I need instructions on how to dissasemble the Sigma 300-800mm f5.6 APO EX DG HSM lens to clean an inner element. Does anyone have a service manual/exploded views/parts diagram please?
You can't do this yourself. It needs to be carried out by professionals and is a 'clean room' with service techs in full dust proof protective wear. Send it to them.
https://www.sigma-global.com/en/support/
1helpful
Putting new gas line on as I have had lots of trouble with gas leaks. anyway gasket fell off of carb. can you send a pic of how it goes on? the gasket that is
Mike,
Sorry to hear the carb is leaking. This happens when the Carb Float Needle gets stuck and is easy to rectify.
If you watch this video on YouTube it will show you how to free up the Float Needle. It is the same procedure on all Carbs:
https://www.youtube.com/watch?v=7LrBmeBcVnA
2answers
I have a rural king generator 6500 E It starts fine but after a few Minutes it dies?
It sounds like it is starving for fuel. You probably need to rebuild the carb.
1helpful
2answers
I Have a Rural King Generator it starts Fine but only runs a few minutes and it shuts off
Make sure the gas is fresh. Also, take off the carb bowl and look for signs of gumming. If there is gooey stuff in the bowl, then the carb needs to be cleaned.
First verify that the breaker for the outlets is not tripped and make sure that the generator is running at full operating speed. let it run for 5-10 minutes and check for output power. If there is nothing, there are two possible problems. One could be that the automatic voltage regulator is bad. The other is that the field needs to be flashed - a high possibility if the generator has not been run in a long time. There are many videos on the internet that show you how to solve both of these problems. Just do a search for No output from a portable power generator.
Where can i find a manual for jd tek 6500e generator
JD Tek 6500E LPG Generator how to install wheels Battery handles
1helpful
Parts diagram for sigma faucet
http://www.sigmafaucet.com/media/cms/specifications/400408.pdf
I found this series on line at the link above the only number off one number off. Check out the link below for all sigma faucets. I hope this will be helpful for you.
http://www.sigmafaucet.com/ecommerce/prod_details.asp?pid=1408470&img=&cid=816144586725
Jun 14, 2010 • Home
2helpful
How many chain links from camshaft sprocket mark to crankshaft sprocket mark on a 4G54
Click on the following free Link. It has the Timing Belt/Mark Diagrams you will need for your 1989 Mitsubishi Sigma.
You can count the number of notches on the Belt giving you the number of chain links between the Front and/or Rear Camshaft Marks to the Crankshaft Sprocket.
Let me know if this helped....
http://www.2carpros.com/car_repair_information/year/1989/make/mitsubishi/model/sigma/1989_mitsubishi_sigma_timing_belt_diagram_marks.htm
7helpful
2answers
I need schematic diagram for gorenje wa 50050 washing machine
I find a schematic diagram on internet address www.masine.sigma-com.
Thank you for trying!
Top Sigma Powers Inc Electrical Supplies Experts
john h
CJ Rock
CJ Rock
Are you a Sigma Powers Inc Electrical Supply Expert? Answer questions, earn points and help others
