Why wont my Panasonic KX-TG5583 allow my handset #8 (KX-TGA551M) to connect to the base? I have tried everything for hours - unregister, take battery out of base and handset both, and it still tells me I have 8 handsets maximum connected and I don't. I have 8 handsets total including the one on the base.. tech support tells me that is correct but they can't tell me how to fix it. I threw the 8th one in the drawer finally. Can anyone help me? THANKS!
It has to do with the electrical load that each ringer imposes on the line. Each set has a limit on how many handsets you can register with it. If you look on the bottom of the base you will see on the identification plate a data item called Ringer Equivalence Number or REN.
In telecommunication, a ringer equivalence number (REN) is a somewhat arbitrary number which denotes the electrical load a telephone ringer has on the line.
REN is 0.1B, but says "Expandable 8" on surface?
I am not sure but what I am suggesting might work. You could try to reduce the Ringer volumee of the handsets. You have a fixed amount of electric energy comming through the wires, that must be divided among several ringers and if they are all ringing at full blast some of them may not ring at all. Can't your phone company offer more power on the line?
Comming : read coming
SOURCE: Hard reset of KX-TCD580 Base
Go to this link; http://panasonic.co.uk/customer-Support/download-centre.asp and input "KXTCD580" in the search box - after a few disclaimer screens you get to the manual for your phone. page 29 details reset for the handset Page 32 details base unit reset Page 48/49 details cancelling handsets to the base Hope this helps, please post again if you are still having problems with your phone :)
SOURCE: no link to base Panasonic KX-TG2357
are you running a wireless router? try unpluging router to test phone.
I’m happy to assist further over the phone at https://www.6ya.com/expert/james_1cb31da1bc8c6102
SOURCE: Panasonic KX-TG2740 Cordless Phone - Can I reset handset registration
press function button on handset, scroll to initial setting, select by pressing right arrow, scroll to registration, select, select hs registration, follow directions on handset display, pressing mute on "new" base station, and ok on handset(plugged in). If you like, you can unregister with the "old" base unit first.
SOURCE: bought new phones kxtga110ex and want to register handset from kxa141es
I can send you a manual. Just email me on [email protected]
1 " (middle soft key) i L i #
2 Enter "335".
3 "Cancel Handset" i #
LThe numbers of all handsets
registered to the base unit are
displayed.
4 Select the handset(s) you want to
cancel, by pressing the desired handset
number. i #
5 "Yes" i # i {ih}
Base Station:
A handset can be registered to a maximum
of 4 base units. A handset can cancel a base
unit that it is registered to. This allows the
handset to "forget" the base unit.
1 " (middle soft key) i N i #
2 "Registration" i #
3 Enter "335".
4 "Cancel Base" i #
5 Select the base unit(s) you want to
cancel, by pressing the desired base unit
number. i #
6 "Yes" i # i {ih}
