Question about Cooking
Freezing avocados I buy avocados at the store and many times they are a)expensive and b)hard to cut up. Since there are seasons where this item is "not in season", I want to know if I can a)freeze any avocados that I buy so as to not lose my money and b) if this can be done, how do I do it? Thank you,Cris Jung
    Sergeant:
  • 339 Answers
You can freeze avocados, but not whole, of course. The best way is to peel them, puree them, pre-mix them with any of the following: lemon(keeps it from oxidizing), minced roasted red peppers etc.... Many recipes are available depending on what you want to use them for.
Make sure you gradually defrost them(in the fridge) for a few hours before you use them. Good eating!
Posted on Dec 05, 2013
My tv screen is black when I turn it on I tried turning the brightness up but it wont work.
When that happened to me, it was because the tube had developed a fault. I could have had it fixed, but it would have been expensive compared with buying an LCD screen. You might want to think about cutting your losses and buying a more modern TV. They don't last as long as CRT TVs but it's hard to get a decent CRT these days, except in a second hand store (although it can be nice and cheap as long as it lasts a reasonable length of time after you buy it)..
Jun 08, 2016 | Televison & Video
Freezing avocados successfully
as with freezing anything especially fruit ! you have to get the air out first , a vac sealer is critical for doing this , there just not that expensive nowdays and every home should have one , why I even vac seal my dogs leftovers saves me tons in dog food !! as barney (dog's name) gets to finish all the can and he doesn't know how long its been open
Mar 10, 2016 | Computers & Internet
220.brigs and Stratton oil how much insump
A small qt bottle of SAE 30 wt oil, of ANY brand is fine for use in lawnmowers. The tolerances for the piston ring and cylinder are not so close to warrant more expensive synthetic blends. A simple std grade (cheapest) 30 wt is fine. It is a good practice to drain and refill your lawnmower engine before each cutting season, replace the air filter, and spark plug. Carburetors tend to foul so empty the gas tank at the end of each cutting season by letting the mower run out of gas... empty the float bowl, if it has a drain screw... this will keep varnish and gum from forming when you store it. Keep a spare cord on hand as they break when you least expect them to and when you need to use the mower. Hardware stores sell replacement cord, just cut to lengths as needed.
Oct 11, 2014 | Garden
Can I freeze fresh avocados they are not ripe yet in my home freezer?
Aboutfood.com, as well as several other websites recommend freezing only ripened Avocados, not un-ripiened ones.
Jul 05, 2014 | Kitchen Ranges
Can I freeze avocados in my home freezer?
Though Fresh Hass Avocados are preferred for their taste and versatility, with the proper preparation, pureed avocados can be frozen and used in guacamole dips, dressings and spread on sandwiches.
Whole, cut, diced or mashed avocados do not have as desirable of a result when frozen. Guacamole can often contain other ingredients that do not freeze well so we do not recommend freezing guacamole.
How to freeze avocados
try doing an avocado puree before freezing it, lasts longer and tastes better than freezing the whole avocado fruit.
Dec 11, 2013 | Cooking
If I combine the avocado with basil etc. to make pesto sauce, can I freeze it in freezer bags to use later?
short answer. yes.
becareful with mixing in an other type of oils or lemon juices etc. as these have different freezing properties and will make the product rehydrate with a lumpy texture. straight Avo with basil blended and popped into a freezer in a sealed container should work no problems. storage for up to 3-5months depending on freezer temps and how ripe the avocado was to begin with.
Aug 25, 2013 | Cooking
What food should I not feed my dog?
You shouldcertainly not feed your dog avocado, raisins, chocolate, raw fish and meat, catfood, and more. For more information on why you should not give these foods(and more) to dogs, go to these websites: http://www.peteducation.com/article.cfm?c=2+1659&aid=1030and http://pets.webmd.com/dogs/ss/slideshow-foods-your-dog-should-never-eat.
Jul 18, 2012 | Dogs
Cooking Logo
1,060 people viewed this question
Top Cooking Experts
Tom Chichester
ray gallant
Clyde Hanson
Are you a Cooking Expert? Answer questions, earn points and help others
