Question about SYMA Toys industrial New Syma S107 Radio Remote Control Helicopter
S107 charger light stays red all the time, doesn't change to green.
I have multiple copters (kids). One of the remotes led lights that indicate charging, on, etc...only lights red even when no copter is charging. It never turns green....except for a split second when I turn the remote off. While it seems to work, I am worried about overcharging copter.
Posted by Joe Anderson on
Julian King
    Problem Solver:
  • 21 Answers
Check the batteries are new or in good condition. Also charging time is approx. 30 mins check in the manual how long charge time is. We also have replacement USB mini chargers available.
Kind regards, Julian.
rccontrolfreak.co.uk
Posted on Jan 31, 2014
3 Related Answers
Anonymous
SOURCE: my syma s 107 copter
Try setting the heli down on a table and with the transmitter behind the heli, turn the throttle up until the blades start spinning. If that doesn't work, then I don't know how to help you.
Posted on Oct 04, 2010
Anonymous
  • 34 Answers
SOURCE: Can't figure out how to
Found this for you.
it appears that the helicopter dynamically configures the control channel upon first detection of a signal from a controller. So, If you 1) turn off the helicopter, then 2) turn on the controller, then 3) select the desired channel on the controller, then 4) turn the helicopter back on, then 5) hold the throttle down on the controller, the helicopter will start up (after a slight delay) and be controlled via the new channel.
Posted on Jan 04, 2011
yiboo
SOURCE: Hi, I just bought your product
you should have charged your heli BEFORE 1st flight.......anyway,,plug computer end of usb charge
cord into computer......turn heli OFF....before you plug cord into heli look at computer end of cord,,
should be bright red light inside......now plug other end of cord into heli.....bright red light goes out!
when heli is fully charged bright light on computer end of cord comes back on......disconnect
heli right away.....if left on charge your battery could wear out....it takes about 50-60 minutes
Posted on Apr 21, 2011
Air Hogs R/C pocket-copter not functioning
your copter might have already experienced some hard bumps or landings , so you might need to check your copter circuit and battery cables to make sure they are in good condition or check the battery itself.
May 02, 2015 | Spin Master 1001130 Air Hogs R/C Pocket...
How do you turn on an HAK 311
On the copter right above the charging hole, there is a little switch. Left is off, right is on.
My copter has the problem that the remote doesn't work, turning it on does nothing, and connecting it to the copter only makes the light on the remote flash red.
HAK 31 is a piece of junk.
Feb 09, 2014 | Electric 3CH Mini Sport RTF RC Helicopter...
Air Hog Pocket Copter won't charge
If this was the original charger for the air hog copter and it just started to fail in recharging , there must be a faulty part inside the charger that is causing the problem, staying red light during charging period and never turns to green or other color to show that it was charged is one problem but when it also shuts off after 30 seconds without charging definitely shows a faulty part or parts inside the charger. To check this out you can try another good charger which you can borrow from a friend to see if it would charge your copter or you can take it to the store where you bought the copter , they may be able to confirm the fault on your charger, if it can be fixed or needs a replacement.
Dec 27, 2013 | Spin Master 1001130 Air Hogs R/C Pocket...
Missing manual, batteries not charging, quad copter not taking off
Go to this page: http://www.helipal.com/faq.php
and scroll down to the technical FAQ and the Walkera FAQ
Feb 09, 2013 | Walkera QR Ladybird Z-02 Canopy
Stunt copter won't sync
I presume you have lights & sound on the controller when you turn it on - fourteen quick beeps and then a different toned fifteenth beep. The screen lights (blue). Insert the battery (lettering facing up toward the helo fuselage unitl it's seated all the way - an LED inside the fuselage, visible from behind, quick flashes and then begins a slower blinking.
Once the helo battery is inserted, turn on the controller, which starts the aforementioned beeping. On the last controller beep the helo's LED will stay lighted, indicating the helo & controller are synched.
I had a problem making sure the battery was inserted all the way into the helicopter. You'll know it's inserted properly when the LED inside the helo flashes.
Dec 26, 2012 | Brookstone Stunt Copter RC Helicopter
Troubleshooting the wireless us eagle copter
The green light won't turn on when I try to charge it on the controller. It also won't charger at all, just the red light on and copter off
Dec 09, 2012 | Sky I Blade Mini IR Helicopter W/ Remote...
I have a nano copter blaster 3D. I have put new batteries in the remote control. When i switch the remot on I get a red light and nothing else happens. It was bought for some friends who returned it...
You have to charge the copter first. Open the cover on the remote control and plug the little cord into the bottom of the copter. Make sure the copter is turned off. Switch on the remote and you will get a green light which means it's charging. When it goes red (about 10 min) it's charged. Then uplug it, turn on the copter and fly!
Oct 10, 2010 | Toys
My copter will not charge i plug it up,make sure copter is in off postion,but red light never goes off and copter never charges,the green light never comes on,this thing has been flown maybe 6 times since...
I just bought one for my Grandson and we had to plug in the outlet to the copter first, before pluging in the AC/DC adapter to the power charger. I know the instuctions do not explain it this way, but the green LED charging light would not come on and it would not charge doing it anyother way
Sep 27, 2010 | Silverlit Toys Ed Hardy 115" Special...
SYMA Toys industrial New Syma S107 Radio Remote Control Helicopter Logo
556 people viewed this question
Top SYMA Toys industrial Toys Experts
Marvin
Marvin
Tom Chichester
ray gallant
Are you a SYMA Toys industrial Toy Expert? Answer questions, earn points and help others
