Question about Cameras
Hello I currently own a BenQ DC 1450 digital camera,the problem I'm having is when I switch the camera on,the LCD screen at the back only gives me two options 'computer' and 'printer'.its not allowing me to take out photos at all,even if I remove the SD card it still gives me the same two options. Please help!!! Thanks, kuben (guest)
    President:
  • 1,082 Answers
Apparently the camera thinks it has a usb wire connected to it. that is typically when these 2 options appear. Look carefully into the usb socket on the camera, and see that there is no debris in there. If so clean out with tip of a splintered tooth pick or similar non conductive item. It's possible the contacts in there are damaged.
What you can do is remove the SD card and plug it into a PC, copy all the pictures off it. You may need to use an SD card adapter thingy to plug it into a PC. (Commonly available) I would then format the SD card IN THE CAMERA, not in the pc. This may or may not help the problem. Otherwise you will need to send it in for repair, (warranty?) or live with it.
Posted on Dec 05, 2013
5 Suggested Answers
Anonymous
SOURCE: Benq Dc 1300
Hi Have lost my BenQ Dc 1300 driver Cd and now i need de Software Thanks
Posted on Sep 28, 2008
Anonymous
SOURCE: Olympus FE-210 Camera Problem
This is a malfunction of the camera. The same thing happened to mine. It gave me the option of power off or format card. I took my camera card to jewel osco and saved all my pictures onto a disc so i could format the card with out losing the pictures. I tried formatting the card and then the camera told me there was a card error. So I went out and paid $25 for a new olympus xd card, put it in the camera, pressed power and it said the same thing fo rthe brand new card that it had said for the card that actually had pictures on it. As far as I know there is no solution to this problem. You can still take pictures if you take your camera card out and use the internal memory. Olympus basically told me that I'd have to pay a **** load of money to have it fixed since the warranty is up.
Anonymous
SOURCE: system error 0013 benq DC E610 DIGITAL CAMERA
i had the same problem but now i have solved it.........its not a software problem..... the lens in fornt of the camera is not able to come out......just hit the camera 3-4 times on a table it will start working.......hope your problem is solved
Posted on Jul 28, 2009
Anonymous
  • 5 Answers
SOURCE: benq dc c500 digital camera dirvers
You can download them from the BenQ site:
http://benq.nl/support/downloads/downloads.cfm/dtype/D/page/downloads/product/830
Posted on Aug 24, 2009
Anonymous
SOURCE: Digital Camera BenQ DC C500 as a webcam
well i havea dc c 500 it works as a webcam on mssnger and yahoo but when i got the new windows 7 it stoped the windows says cant fint a software i need help
Posted on Sep 17, 2009
How can i charge my benq Dc x725 digital camera on my computer i dont have a manuel
Hello and Welcome to FixYa!
To download manual of Benq DC x725 Digital Camera. GO HERE.
You can easily get manual from here.
If you find my solution helpful for you the your Rating as FIVE STARS will be esteemed.
Thank you for using FixYa!
Dec 11, 2011 | BenQ DC X725 Digital Camera
My camera just stopped working. when i turn it on the lense open slightly and the lense wont come out as usual and the light shows for 5 seconds blinking then goes off. the model of my camera is a BENQ DC...
Your batteries have worn out. They don't give enough power for the camera to switch on properly.
Replace the batteries. Use 1000mAh or better batteries.
Aug 21, 2011 | BenQ DC X610 Digital Camera
Is there a way to get the DC E53 camera to accept a larger SD card than the 512mb that it currently accepts?
The following link describes the maximum SD card size for your camera.
http://www.mymemory.co.uk/compatible-memory/Digital_Cameras/BenQ/BenQ+DC+E53_Memory_Cards
The following is from their site:
BenQ DC E53 BenQ DC E53 Memory Cards (SD Card) & Accessories
The following digital camera memory cards are compatible with your BenQ DC E53. Every digital camera memory card we offer is manufactured to the highest standard and carries a 2 year minimum warranty.Your BenQ DC E53 accepts SD Card cards.The largest SD Card card you can use in your BenQ DC E53 is 2GB
So you can buy up to 2GB SD cards.
Jan 05, 2011 | BenQ DC E53 Digital Camera
Lcd is damage need replacement.. where can i buy lcd of benq t700
You can buy benq t700 lcd from about $27 approximately.
This is the link of seller's address.
Feb 24, 2010 | BenQ DC T700 Digital Camera
Drivers
how can i install my benq c500 webcam in my pc
Jul 08, 2008 | BenQ DC C500 Digital Camera
System error 0013
I have a digital camera Benq dc E610, it showing error 0013 while switching on.
Mar 01, 2008 | Nikon Coolpix 3200 Digital Camera
Benq Dc 1300
hello..
here is the link for your driver download needed.. i hope it helps you out, please let me know..
http://www.nodevice.com/driver/DC1300/get32948.html
thanks..d
Feb 29, 2008 | BenQ DC1300 Digital Camera
Connecting digital camera to pc
Hello i have Benq DC C640 camera
and when i try to take photo it sayes card lock, even when i changed the simcard it still sayes the same problem . Help please
Oct 03, 2007 | Cameras
Problem with my digital camera
I also have the same problem, would appreciate it if you get a respone to let me know what happens,address is:[email protected] in the meantime I will check back to see if you get any replies. I also am desperate!! Thanks
Jan 17, 2007 | BenQ DC S30 Digital Camera
Cameras Logo
51 people viewed this question
Top Cameras Experts
Ekse
Marvin
Marvin
Are you a Camera Expert? Answer questions, earn points and help others
