Heating & Cooling Logo
Posted on Dec 05, 2013
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Diverter valve? I can get hot water eventually but I have to jiggle programmer, changed Honeywell control on diverter valve but no different, any ideas?
mikadot
Level 3:
  • Master 2,113 Answers
  • Posted on Dec 05, 2013
mikadot
Master
Level 3:
Answers
2113
Questions
0
Helped
466356
Points
5959
It's likely a zone valve. It may need replacing The actuator may be seized To verify check that it is getting 24 VAC If not then check the transformer that supplies it for 24 VAC.
Honeywell technical support
This boiler, from memory, has an electric diverter valve.
If the system has dirty (sludge/scale laden) water then the diverter valve may not return under spring pressure, and therefore not divert all of the hot boiler water to the hot water heat exchanger, leaving some going to the rads.
If I am right then the rads will not get fully hot.
If the valve has failed completely, or electrically, then the rads will get fully hot and there will be no hot water output (hot water will be cold).
Heating and hot worker work separately but not together
If this a honeywell valve you may need to change the motor in side the valve , sounds like its lost some of it power to move the inside of the valve to y postion .
Heating not working and Honeywell Thermostat Heater states that the temperature is 45 degrees celsius.
without seeing it its hard to say, the thermostat controls the boiler and/or diverter valve depending how its been wired, the diverter valve shunts the water to were its needed ie from one circuit to another if you have two therostats there is a conflict somewere, best bet to have an engineer sort the wireing out
User guide needed for old Honeywell programmable heating control
It depends on your system some will only work with hot water on and heating do you have two zone valves?
1helpful
Have hot water but no radiators. Checked pilot
sounds like your circulating pump is bad or electronic zone valves
2helpful
Heating circuit getting hot when hot water is running
Check to see if diverter valve is in domestic mode or heating mode.
Cannot get central heating working,for honeywell ST6400 programme
with y plan 3 connections on programmer HW on HW off CH on HW on to cylinder stat then HW call to Orange on Mvalve to power boiler and pump HW off to grey wire on Mvalve to close hot water CH to room stat common then heating call to white on Mvalve
Top Heating & Cooling Experts
Paul Carew
john h
