Question about Braun Silk-epil 3370 Epilator
Main rotator/lever not working
The motor is absolutely fine but the epilator is not working. How do I open the body and replace the lever?
Posted by Masuma Khan on
2 Related Answers
Anonymous
  • 276 Answers
SOURCE: main rotator is not working although the motor is fine i dont kno
I have access to Use Instructions if you wish, I can put them on our website if you want.
Posted on Apr 10, 2009
Desiree
SOURCE: My Silk Epil 7 has
Hello, I had the same problem as you guys: the performance of my epilator got really weak and I found out there was a lot of hair inside its head.
I tried to open it but couldn t find the appropriate tool. What did you use, a screwdriver or a key?
Posted on Aug 22, 2013
Plugged in india without transformer
It is hard to say. If the device has a fuse fitted inside then it may only be that needing replacement. If the motor or other circuitry is burned up, then just buy a replacement unit.
4helpful
3answers
My Silk Epil 7 has stopped working, the epillator head has stopped rotating. I doubt that some hair has got stuck inside. Could ypu please help?
My Braun worked fine the last time I used it & would not come on when I tried it today. Worked on it & found it to be jammed with hair. Would not rotate. Scrubbed it with a toothbrush, started digging out the hair, forced it to rotate, scrubbed it some more, & rotated it some more. The more I worked with it the more hair kept coming out. It's rotating fine now. I think I'm going to clean it with my water pik. My Braun is the kind that can be used with water & the top part comes off. Haven't used it yet but I think I have fixed it. Wish I could get it apart to clean it out but the head of the screw is strange & I don't have anything that will turn it.
2answers
How to clean a remington EP6010 epilator?
AFTER EACH USE
CLEANING THE EPILATION HEAD Ensure the epilator is turned off and disconnected from the mains. Press the head release button/s and open the head assembly. (Diagram G) Turn the head assembly upside down. Using your thumbs, push the small sides together and push the epilation head upwards. This releases the curved epilation head. Brush the accumulated hair from the tweezers by turning the barrel manually. NOTE: The body of the epilator is not washable. Do not submerge in water.
TO REMOVE RESIDUE To remove residue from the stainless steel tweezers, dampen a swab with alcohol. Gently run the swab over the tweezers until the residue has been removed.
Online Manual: http://uk.remington-europe.com/pdf/ep6010_user_manual.pdf
1helpful
My braun silk epil xelle is still working but not as good as i purchased it about 2 years ago. it doesn't sound and rotate powerful enough. i want to disassemble it but cant figure it out!
Probably a whole bunch muck is inside theyre (science Project ewe), are you sure you want to open it up? ok... there should some screws underneath the plastic covering but you will need to kind of rip that off and reapply some sticky appoxy after.
Broke my Braun Silk Epil Xpressive
Hey , were your able to find any solution for your problem. I opened my epilator and now this wire is not in its place. I dont remember how it used to be :(
3helpful
Main rotator is not working although the motor is fine i dont kno
Braun Silk-epil 3370 Epilator Logo
Top Braun Health & Beauty Experts
shaveroutlet.com
shaveroutlet.com
reference30
Michael Thomas
Michael Thomas
Are you a Braun Health and Beauty Expert? Answer questions, earn points and help others
