Question about Carrier XHB123D X/Y Series Heat/Cool Air Conditioner
What does a heat pump compositor do - Carrier XHB123D X/Y Series Heat/Cool Air Conditioner
Kxf 450 2013 starts up when cold let it warm up leave it an hour will not start
I started with an answer but it probably got sent before I was finished. It could be your computer breaking down as it heats up. I have fixed things by spraying the component with freeze spray and then trying. That is after it heated up and engine stopped. There are components that do break down when heated if they are malfunctioning. There are sensors that may act similar to a capacitor and breakdown after heating up. You may if you have got a service manual try some sensor that are in the start section. I. think one is used instead of a timing light and is still fixed on or near the fly wheel. Another may be in the throttle section. A condenser is nothing more than a large capacitor so that is a good place to try as well. Capacitors do breakdown after heating up like that if they are malfunctioning. Components going to coils could also cause the problem. If you have a spare Computer I would try that first. I had a car that would skip and stop and the computer was the culprit. My brother had a timing sensor problem on the flywheel as well. That is if it has one and if not try Condensers by spraying them with freeze spray you can get from Source and other electronic stores. I have fixed many Electronic devices with freeze spray.
Feb 08, 2015 | ATVs
I have a RUUD Model UGPH10EBRJR. the compositor near the blower motor in the ****** is bubbling out some kind of jell substance. Do I need to change it and do I call it hte run or start compositor. wh
Hi Jerry, yes, whenever you see either end of a capacitor bulging and or leaking fluid, the capacitor is bad and needs to be replaced. It may still be operating the motor ok, but it will eventually fail and the fluid is also highly corrosive. Simply match up the proper voltage and uf to get the proper replacement. Example: 5uf 370 volt or 7.5uf 370 volt or 10uf 440 volt. The uf stands for microfarads. Hope this helps!
Jan 17, 2015 | Ruud Heating & Cooling
Sta rite pro jet 3/4 hp seems to be frozen..turn on and it hums then quits ..no water pressure
it sounds like you have a bad starting compositor. If your compositor is a black plastic one look next to the spade connectors in the cap and you'll see a little resest hole with a brown stopper in it. If that stopper is black, burnt or leaking oil it is bad. If you have a metal one you can set it on it's base on a flat surface. If it rocks it is bad. If the compositor is good you may have a problem with the windings and either need to replace the motor or have it rebuilt.
http://www.austinpooolspecialist.com/
Jun 25, 2014 | Sta Rite 1 HP Sta-Rite Pump: 1.5" in/out,...
Keeps tripping turning off Put new compressor New compositor New breaker Still making a horrible knocking sounds n then trips
call the service co. who replaced compressor . they ether got a defective one or never replaced yours . (compressor is a motor and a pump sealed in a metal can suspended in oil on springs ) apparently yours has a broken one or more springs .allowing electrical field windings of the motor to come in contact with the case shorting out your breaker. solution new compressor!
Apr 04, 2014 | Heating & Cooling
Hp pavilion a6000
Is anything happening when you turn the switch off and on again?
If not you may be hanging on the BIOS somewhere.
Been "fiddling" around?
Jan 27, 2014 | HP Pavilion A6000 Series,amd Athlon 64 X2...
Every time i turn on my sony PFM-42x1 the screen flickers and blinks with colored lines all over it. at first it flickers very fast and as the tv "warms up" the flickering slows down until it stops all...
I have the same TV with the same problem. I am sorry that all the answers are so silly and basic. I just open up mine to check all the compositors to see if their are any Bulging or to see if anything looks damage. I will pull the Power supply and start checking the compositors. and let you know. I will look in other places first to see if I can get some REAL Answers. Poco Zocko Actor
Oct 13, 2013 | Sony PFM-42X1 Plasma TV
When I want to start the pump, I hear a click inside the panel but the pump won't start + three lights a re flashing on the board!
Check the voltage at the back of the pump. If your getting the correct voltage check to see if the motor is free. you can do this by removing the small shaft cover at the back of the motor and try turning the shaft with either a screw driver or wrench, depends on the motor. If it is free check the starting compositor. (a black on will have a dot where the wires go, if it black, blown out or leaking oil it is bad. A silver one is not always easy to tell with out a tester. If you remove it and set it on a level surface, flat bottom side down, and it rocks it is bad). If it is good and your sure your getting the right voltage and the motor spins freely your going to have to replace the motor or have it rebuilt.
If your not getting voltage and the jets indicator icon or light is on you may have a bad relay on the board.
If your still having the issue feel free to contact me and I'll walk you through what I can to get you fixed.
Oct 02, 2013 | Saratoga Spas Pool & Spa
Hi i have a sony PFM42X1 has vertical lines over entire screen, on turn on. has a horizontal line across the middle of the screen. the colour is mixed pink,yellow and green. you can see the ghosting of...
I seen 2 post with same problum diffrent explations, I have the same TV with the same problem. I am sorry that all the answers are so silly and basic. I just open up mine to check all the compositors to see if their are any Bulging or to see if anything looks damage. I will pull the Power supply and start checking the compositors. and let you know. I will look in other places first to see if I can get some REAL Answers. Poco Zocko Actor
Oct 02, 2010 | Sony PFM-42X1 Plasma TV
Acer al1713 monitor and the power led flashes form yellw to green
The short answer, replace all of the capacitors. They can be bad without swelling. And there may be one 47mf/16v off to itself, if it fails, monitor will not come on. Also, check the menu or mode setting to make sure your VGA/DVI agrees with the cable if the monitor has both.
Jan 01, 2010 | Acer AL1713 17" LCD Monitor
I have a booster pump to increase the water pressure to my RO.The problem I have is that when I initially turn my pump on the motor hesitates to turn for around 3secs before it starts.Please could you help
you want to check and see if it has a unload er valve to the unit. also check the amp,s to the unit. example 12 amps to run 24 to start. check your starting compositor. good luck
Oct 13, 2009 | Plumbing
Carrier XHB123D X/Y Series Heat/Cool Air Conditioner Logo
122 people viewed this question
Top Carrier Heating & Cooling Experts
Dennis Boxerman
jdthefixer
Marvin
Marvin
Are you a Carrier Heating and Cooling Expert? Answer questions, earn points and help others
