Westclox Big Ben Moonbeam Alarm Clock Logo
Question about Westclox Big Ben Moonbeam Alarm Clock
Alarm quit working
How to shut off alarm
How to Shut Off a Car Alarm That Won't Quit: 8 Steps
www.wikihow.com > ... > Car Electronics > Car Alarm Systems
wikiHowHow to Shut Off a Car Alarm That Won't Quit. There are a number of reasons why acar alarm might not shut off properly. When it's your neighbors alarm
The alarm wouldnt quit going off i got it to quit and now the car wont start but the battery is charged d o reset it somehow or is there a code to fix it ?
try locking and unlocking your doors , look at the alarm light see if it is flashing or if it is on with out flashing , if its flashing it means the alarm is off if it is soled it is set , if this doesn't work then disconnect the battery for 1 minutes or more
How do i reset car alarm?
check your manual or go to your dealship
My 2000 hyundai tiburon alarmed itself and the alarm is sounding. I have no remote control that works.
Put key in ignition, turn all the way forward, but not trying to start. Let alarm cycle 2 times, when it stops the 2nd time, remove key and alarm should be disarmed. This will only work if it is a factory alarm.
1helpful
Alarm set
this is a factory alarm, the problem is the alarm is active, you will need to use the door locks to turn alarm off, insert key in driversdoor and lock and then unlock door this will turn alarm off, if that doesnt work then use pass/side door, the lock has a built in switch that knows when the door is locked or opened, the driversdoor may have a bad switch so inturn the computer thinks the door was forced opened without key and it is turning alarm on, so again use the key to unlock door try the pass/side if driversdoor doesnt work. good day
3helpful
Alarm went off and key fob quit working
start the car. if that dose not work remove ground form battery then after it stops put ground back on that will reset the alarm.
2answers
My clifford concept 400 car alarm isn't working on my 96 acura integra. With the key on the radio and power antennae will work. The headlights come on but the dash clock does not nor do the wipers or power...
are you sure its the alarm? and do you have the red key for the car? hondas have a immobilizer and they quite often lose the code by themselfs hence you need the red key to reprogram it. If you dont have it then it may be quite expensive.
If you have the key to disable the alarm I would try that first, small key on the side of the alarm box turn to off and try it again.
Hope this helps
Top Westclox Audio Players & Recorders Experts
nexrad_chris
Ngoro
Are you a Westclox Audio Player and Recorder Expert? Answer questions, earn points and help others
