Motorola talkabout manual
Beeps every time you push the button to talk .how do you turn it off
Posted by jeff on
HawkLore
    Scholar:
  • 98 Answers
I have a bunch of these. Here is a link to the manual. Go to page 21 for your answer.
http://www.motorola.com/mdirect/manuals/t50-t55_userguide.pdf
Posted on Dec 05, 2013
When I press the push to talk button on my Motorola talkabout 250 there is a constant beeping noise and I cannot transmit
Generally a constant beep is the sign of a low or bad battery. However, it is noted the TalkAbout 250 is operated with AA batteries, and it is likely you have considered this and changed batteries. You might check your battery contacts, and clean them with a pencil eraser to assure they are making good connection. Otherwise, you may have a failing radio.
Best regards.
Nov 02, 2010 | Motorola Talkabout FRS 250 (14 Channels)...
I have held the - sign and done this several time and the Roger beep is still sounding what next?
The T6500 is slightly different than many of the other TalkAbout radios where the + (plus) button turns the Roger Beep (aka talk confirmation tone) on or off.
T6500 will turn ON the Roger Beep when turning the radio on with the +, but to shut it OFF you must hold in the - (minus) button while turning the radio on.
Here is a link to the user guide: http://www.giantintl.com/ContentManage/manuals/Moto/T65xx.pdf You will find the instructions in detail on page 25.
Best regards.
Oct 13, 2010 | Motorola Talkabout T6500 (7 Channels)...
Cant turn off beep on motorola T6500
You may be referring to the Talk Confirmation Tone (Roger Beep). This feature is turned off by holding the minus (-) button while turning the radio on. See page 25 in the user guide: http://www.giantintl.com/ContentManage/manuals/Moto/T65xx.pdf
Best regards.
May 31, 2010 | Motorola Talkabout T6500 (7 Channels)...
How do I turn off the beep when pushing the talk button?
You will find both Call Tones and Talk Confirmation (Roger) Tones on page 25, with a full explanation of turning them on and off.
Best regards.
Nov 28, 2009 | Motorola T6510 XLR Talkabout Two-Way...
Motorola talkabout 250 beeps when the talk button is pushed
The radio has possibly been damp or wet. Take the battery pack out of the radio and allow the radio to dry, or to speed the process try using a blow dryer on a low setting.
Check your programming and be certain your large and small numbers match one another when you get ready to try the radio again.
Here is a manual which most closely matches your radio type: http://www.usersmanualguide.com/motorola/2-way_radio/t280
Nov 17, 2008 | Motorola Talkabout FRS 250 (14 Channels)...
Shutting the beep sound off when you turn on talkabout T7150
Button Beeps
Every time you press a button on the front of your radio, it beeps unless you turn
Button Beeps Off. To turn Button Beeps Off, turn your radio On while you press and
hold the minus (-). To turn Button Beeps back On, turn the radio Off and then back On again
while you press and hold the minus (-) . On is the Default setting.
http://www.motorola.com/mdirect/manuals/T7100_UserGuide.pdf
Nov 15, 2008 | Motorola Talkabout T7150 Two Pack 2-Way...
Fr50 beep
Hello mtnrvr,
The Motorola TalkAbout radios, especially the FR50 and FR60, are notorious for making a variety of beeps when you push buttons and activate various functions of the radio.
The beeps can be helpful when you are trying to operate the radio in low-light situations. But they can also be mildly irritating.
Sadly most models of TalkAbout do not provide any way to disable the beeps. I'd suggest not using this particular radio for covert surveillance missions.
Best Regards,
Agent Ken
Go Ahead. Use Us.
Apr 12, 2008 | Motorola Talkabout FRS 250 (14 Channels)...
Muting the sound
The sound produced by a Motorola radio when the mike is keyed refers to the "Transmitting Call Tone" which is another feature other than the "Interference Eliminator" or the "Roger Beep" feature.
On most Motorola GMRS/FRS TalkAbout radios, setting the "Call Tone" to 0 disables the feature. This is done with the radio ON by pressing on the "Menu" button 3 times which will result in the display showing the current Call Tone setting (flashing) and the letters CA; pressing on the <- or +> buttons will change selection (you will also hear the different Tones), select 0 (it may be up to 5 or 10 depending on the version). Press on the "Menu" or "PTT" button to set, save and exit.
Hope that this be of some help/idea. Pls post back how things turned out or should you need additional information.
Good luck and kind regards.
Nov 25, 2007 | Motorola TalkAbout T5530 2-Way Radio
Televison & Video Logo
24 people viewed this question
Top Televison & Video Experts
Marvin
Marvin
