If you want technical support of Toshiba, you can contact us on Toshiba Printer Support 1-866-877-0191. We are always available with technical experts for your help. For more information, click https://goo.gl/tCuWe2
Technical Support ' Suport & Drivers ' Toshiba Copiers
www.copiers.toshiba.com/usa/support/support/
SOURCE: Error code C380 paper feed failure
c380 indicates auto-toner error for black developer (K).
Check following:
Is the harness between the LGC board and the developer unit drawer connector open-circuited?
Is any harness inside the developer unit or the auto-toner sensor harness open-circuited?
Is the auto-toner sensor connector or the connector CN341 on the LGC board disconnected?
IF connector no problems, then u probably need to replace the auto toner sensor.
SOURCE: compatability issues with Toshiba e-studio 350 copier and Windows Vista
you click on this site and get the driver which you needed.
http://eid.toshiba.com/support/controllers/ebridge350-450.shtml. or check whether you yo are having any printer enable or anything you just update it.
IF YOU ARE HAVING NETWORK PRINTER
If you still have issues just type the ip address of the mfd in the internet explorer tab. then a screen appears. It is called Top Access. There you can see several settings just try it.
Need further assistance mail me at : [email protected]
SOURCE: C448 on Toshiba e-studio 2500c
C448 indicates Heater lamp lights continuously for a certain period of time when the pressure roller temperature during ready status is higher than the specified.
1. Clear status counter
Enter 08--> 400 --> change the value from "32" to "0", press Enter and restart MFP.
If occur again, u need to check followings:
1. Check the power supply and fuser unit
2. Check the LGC board
