Question about Sears Craftsman LiftMaster Chamberlain Garage Door Opener Wireless Keypad Model 976LM Security+
SOURCE: Chamberlain Liftmaster Pro. Garage door Problems closing
The sensor eye - or more likely, the other end, the sensor light - probably got knocked out of alignment. The eye should have an LED on it - possibly one that glows green when it's ready to close or red when it's obstructed or out of alignment. Try adjusting the light until the LED on the receiver glows green.
Posted on Dec 07, 2008
SOURCE: Liftmaster 1265LM 1/2 HP does not open or close with remotes
is chain moving. if not, gears are shot. if moving, is trolley connected.
Posted on Jan 15, 2009
SOURCE: Craftsman Garage Opener Clicks only and LED blinking 5 times
first off, hitting extra button on remote would not do anything. Is door up or down/ where is trolley that attaches to chain, by door or motor. Is is jamned against a bolt. Try a paper clip and jump from white to read terminal. Does it work. Does light bulb blink 10 times. I ignore the diagnostic lights and go by symptons. Give more info.
Posted on Feb 12, 2009
SOURCE: Liftmaster wireless keypad closes but won't open the door
If you are sure the battery is good you have a bad keypad. The signal strength is so weak it will not penetrate the door.
Posted on Aug 25, 2009
SOURCE: I have a liftmaster door opener model 41a5021-1d
Check the door springs. You may have a broken one. You should also remove the cover and check the drive gear. It is white nylon and is just in front of the motor.
Posted on Nov 21, 2009
Jan 10, 2016 | Sears Craftsman LiftMaster Chamberlain...
Oct 22, 2013 | Sears Craftsman LiftMaster Chamberlain...
Aug 24, 2011 | Sears Craftsman LiftMaster Chamberlain...
Apr 10, 2011 | liftmaster Garage Door 1/2 Hp
Jun 13, 2010 | Sears Craftsman LiftMaster Chamberlain...
Mar 22, 2010 | Sears Craftsman LiftMaster Chamberlain...
Feb 02, 2010 | Sears Craftsman LiftMaster Chamberlain...
Jan 12, 2009 | Sears Craftsman LiftMaster Chamberlain...
Jan 05, 2009 | Sears Craftsman LiftMaster Chamberlain...
Dec 29, 2008 | Sears Craftsman LiftMaster Chamberlain...
52 people viewed this question
