Question about Juicers
My juicer keeps blowing its fuse and also tripping main electricity switch
1st time it happened i changed the fuse but it immediately happened again.
Posted by catriona lane on
My juicerator just quit working. Won't turn on. Is there a fuse?
sometimes continuously using of any electrical appliance trips due to overload heating up fuse inside and turn back on again after some time... thank you
Mar 27, 2016 | Juicers
How to fix juice extractor?
if it has current and the switch is good there is a thermal fuse needs to be replaced if you know electrical rated at 8 - 10 amperage inside machine
Jun 21, 2014 | Hamilton Beach 67700 Fountain Juicer
Is it possible to blow a fuse in the JEX 328?
yes it has a thermal fuse inside, small as an aspirin rated at 8-10 amps about $ 5.00 us we have replaced most with a reset button circuit breaker , best idea I came up with for $ 12.00 us
Mar 25, 2014 | Waring JEX 328 Health Juicer
Philips Avance Juicer 1871 has just completely stopped while juicing lemons - its been cleaned and nothing is stuck, what should I do? Its only 3 months old.
Push the reset button underneath - this worked with mine when the same happened to me; I only realised it was there after changing the fuse, which didn't fix it. I turned it over and found the button and voila!
May 17, 2012 | Juicers
I have an acme juicerator 6001 model and I was just juicing... i put vegetables in before it was quite warmed up and it looks like something happened to the motor. Is there a way to fix this?
You may have tripped the reset button on the bottom of the juicer, just push
it back in. They really don't have to warm up, just give it a few seconds to reach
speed.
Apr 21, 2011 | Acme 5001 Supreme Juicerator Juice...
I have Jack Lalanne Power Juicer 250 Watts and it will switch on. I have changed the fuse, but to no effect. Any suggestion?
The stainless bar should be on the correct slots on top of the juicer. It has a safety switch on those bars. Smell the motor from under the juicer, it should not smell like burnt. Press hard on the switch, it might be loose.
Oct 24, 2009 | Jack Lalanne Power Juicer 250 Watts
Juicer no longer works !
the motor uses a tiny fuse in the windings and it might be hard to find and rated up to 15 amps... it blows sometimes for no reason and especially on cold starts.
also the on-off switch wears out.. and lastly the ac cord breaks inside from stretching too much.
Jan 30, 2008 | Champion 2000+ Household Juice Extractor
Omega 4000 won't start even after reset
LOOK UNDER WHERE YOU PUSH DOWN
ON THE LATCH ARMS TO SECURE THE
LID. ONE ONE SIDE THERE MAY BE A
SMALL INTERLOCKING SWITCH WHICH
WOULD PREVENT THE JUICER FROM
RUNNING WITHOUT THE COVER LOCKED
DOWN. USE A SMALL SCREW DRIVE TO
CORRECT IF MISALIGNED. THE JUICER
ALSO COMES WITH A 15 YEAR WARRANTY, SO OMEGA WILL FIX FOR
FREE.
Oct 31, 2007 | Omega 4000 Juicer
The reset button
IT'S THE RESET BUTTON AND THEY ARE
ADJUSTABLE. REMOVE 4 SCREWS UNDER
JUICER TO REMOVE BOTTOM. YOU CAN
GET AT THE RESET BUTTON HOUSING AND
ADJUST THE SMALL SCREW EITHER WAY.
YOU WILL HAVE TO FIGURE OUT WHICH
DIRECTION. CLOCKWISE OR COUNTER.
IT YOU GET IT WRONG IT WILL CUT OUT
MORE FREQUENTLY SO JUST GO THE
OTHER WAY.
Oct 06, 2007 | Acme 6001 Juice Extractor
Overtemp switch keep tripping
REMOVE BOTTOM AND TRY ADJUSTING
RESET BUTTON BY TWEAKING SMALL
SCREW ON BUTTON HOUSING. TURN
EITHER WAY TILL YOU HAVE LONGER
RUN TIME.
Sep 04, 2007 | Omega 9000 Juice Extractor
Juicers Logo
283 people viewed this question
Top Juicers Experts
Bill Boyd
ray gallant
Tom Chichester
Are you a Juicer Expert? Answer questions, earn points and help others
