Question about Juicers
Will not start i it isn't a jam. - Juicers
Posted by arthur on
  • arthur
    arthur Dec 05, 2013
    Was juicing carrots & suddenly the juicer stopped. I thouroughly cleaned it & it is jammed. Is there a fuse inside that may have blown?
Pusher stuck in fusion juicer
May not be repairable if pusher is distorted or damaged. If jammed with a foreign body, need to carefully pry apart and clean out. Find a handy person and offer a fine juice meal.
Nov 25, 2014 | Juicers
Hi- I wanted to use my juicer again after not having used it in at least 2 yrs. Last time (which I can't remember!) I used it, it worked. This time, all loaded up with veggies, when I turned it on it...
Just looked at mine because I thought there also might be an interlock switch
where the latch arms snap shut. There isn't one, at least on this one. Yours
might be a newer edition, so make sure the latch arms are fully seated and
snapped closed. You can also call Omega at 1 800 633 3401 and run it by
them. The reset switch should be in the pushed in position, it will pop out if
it's tripped.
Apr 29, 2011 | Omega 1000 Juice Extractor
Juicer was working 5 seconds ago. now it won't work at all...does anyone know who fixes these things.
did it get jammed? sometimes that happens when my kids feed the vegetables in way too fast...I open it up, clean out the jam, put it all back together and it works again. also if it is 'full' and won't take anymore produce it will jam too. hope that helps
Jan 07, 2011 | Jack Lalanne Power Juicer (Stainless...
Motor is humming not working .. stoped in between juicer
it is jammed, or it is too full....stop, take apart, scoop out pulp, put back together and restart. go slow when juicing...too fast will jam it!
Pusher is jammed and won't come our
there should be a flat part on the pusher and a flat part on where you put it into...This happened the first time I used it. It will take 2 people but one of you holds the machine while the other pulls on the pusher. I recommend the stronger one pull. Also make sure it is unplugged and that it is off.
May 22, 2009 | Jack Lalanne Power Juicer 250 Watts
Stop running in the middle of juicing
well this is very common with this version, clean inside out, shredded fruits and veggies tend to stick and jam blades.
Jan 09, 2008 | Jack Lalanne Power Juicer (Stainless...
Juicers Logo
111 people viewed this question
Top Juicers Experts
Tom Chichester
ray gallant
Bill Boyd
Are you a Juicer Expert? Answer questions, earn points and help others
