Question about Zanussi IZ161S Front Load Washer
Door seal cant get it on
Posted by mumsey0104 on
Anonymous
    Director Badge:
    Uploaded 100 video answers.
  • 213 Answers
Follow these steps to replace your door seal:
For all Free appliance repair videos visit our VIDEO TUTORIALS
Disconnect all power to the machine first!!
1 Locate the outer clamp band securing the seal to the door rim on the washing machine and examine it carefully for holes or tears. Many can be prised off with a flat-bladed screwdriver they have a spring system holding them, but some have a tensioning arrangement that has to be loosened.
2 After removing the outer clamp band, locate the inner one securing the seal to the drum and establish how this is secured. It may be necessary to loosen a clip, or you may be able to prise the band off with a flat-bladed screwdriver. Some are like very large Jubilee clips that you have to undo usually from the top.
3 Once the clamp bands have been removed, use both hands to pull the seal away from the inner drum rim. Some machines have a water spout holes that will have to be lined up. Others have a drain holes.
4 Rubbing a drop of washing up liquid into the groove on the door seal/gasket that locates on the drum makes fitting the new seal easier.
5 the new washing machine door seal should be fitted by locating the drain holes at the bottom of the seal first then push it on with both hands working opposite directions towards the top. This is quite hard if you have never done it before.
6 refit the inner band remembering this must be tensioned correctly for it to be water tight.
7 now fit the outer band and the test the machine for any leaks,
All washing machine spares featured in this article are available at apart4u with more video help in our tutorial section.
Information provided is a guide only. aPart4u accepts no liability for any problems occurring whilst attempting any advice shown. If in any doubt about fixing your appliance, always contact a qualified repairer.
Posted on Jan 19, 2010
Door seal
get on the mfg. website for listed dealers if no luck call the mgf. for info.
Jul 04, 2012 | Bush DW5F 22 in. Dishwasher
I CANT GET FRONT OFF HOTPOINT AQURIUS TI CHANGE RUBBER SEAL
to change the door seal you have to take the front boot ring off fold the door boot into the drum and undo the retaining clip around the door seals inner drum you can get a screwdriver in from the top a bit tricky but its the only way as the front is riveted on and wont come off like the older machines
Dec 08, 2011 | Hotpoint Aquarius WMA56 Front Load Washer
Water is leaking from the door seal I need to
Before you remove the door, be certain the bottom seal is not folded forward so that it does not seal. I fixed mine by opening the door partway and running my finger along the bottom, pressing the seal back in. If you need the manual, it is here: http://www.manualshark.org/b/zanussi-6/ One of my favorite appliance help websites is: http://fixitnow.com/
Oct 31, 2009 | Dishwashers
Door seal leaks cant how to remove and reinstall
1: remove the top panel
2: remove the lower front panel
3; remove the control panel
4: remove the screws holding the door switch
5: remove clamparound the door seal and remove front panel (2 screws bottom and 2 up)
6: remove clip around door seal that holds tothe tub
7: replace seal....
there you go!!!
Jul 04, 2009 | Whirlpool Washing Machines
The door seal is very dirty and dont know how to clean it and the filter needs changing
well u cant really clean a door-seal once it has become badly stained this is caused by closing the door after the washer has finished it needs to be left open to let the seal dry other wise the moisture cant evaporate which it needs to not stain if u email what make of washer this is i can try and help u with a step by step instructions on the best way to change it it will only cost u at the most £15 to buy but if u pay someone to fit it it will cost u about £80 to have done
Jul 20, 2008 | Washing Machines
Need advice on how to replace brandt CFA361XU freezer door seal.i have the new seal but cant remove the old one.cant see any retaing screws.and seal doesnt seem to pop out. thanks
i shouldn't do it
seal is foamed in and i'v not had any success on replacing foamed in seals. applies to all makes
sorry to be negative
Jul 02, 2008 | Refrigerators
How do you clean the interior, I have a gross mildew looking build up on the rubber seal?
you cant really clean the door seal it will need replacing why you get the mildew on the door seal is that when you finish washing you close the door but this is a mistake never close the door as this lets the rubber seal dry and the moisture that evaporates goes into the atmosphere if you close the door the moisture never drys which causes the mildew
Jun 11, 2008 | LG Washing Machines
Bosch washing machine
i am recently retired appliance engineer of 20 years, the rear door seal clamp is generally nowadays a large thin spring that is slightly hidden by the concrete weights at the front of the drum, if thats the case the door seal will just come off with a good firm pull round the drum edge, fitting as a reverse of removal, place the door seal in the groove so it fits like it should, then stretch the spring and fit that into the outer groove round the lip of the door seal at the drum end, once that is done fit the seal on the front panel lip, then replace that clamp, check all is fitted securely before running machine its one of those jobs that hard to explain how to do it, hope i have helped a bit, its easier to work through the front door opening than from above? if i have please rate me thank you
Sep 13, 2007 | Washing Machines
Zanussi IZ161S Front Load Washer Logo
75 people viewed this question
Top Zanussi Washing Machines Experts
peter gittos
peter gittos
Marvin
Marvin
Michael Thomas
Michael Thomas
Are you a Zanussi Washing Machine Expert? Answer questions, earn points and help others
