RCA RCR3273 3 DEVICE SNOWBOARD UNIVERSAL REMOTE
I have the RCA RCR3273 3 DEVICE SNOWBOARD UNIVERSAL REMOTE and was wondering if anywhere online has codes for this remote?
  • 16 more comments
  • Anonymous Dec 13, 2007
    I need to know how to program and what code do I need for a sharp MTS TV
  • Anonymous Dec 19, 2007
    RCA RCR311ST remote control
  • hyhyhy90 Dec 31, 2007
    need the codes for this remote help anyone
  • Anonymous Mar 03, 2008
    need codes too
  • Anonymous Jul 08, 2008
    how do you program the code?
  • Anonymous Jul 16, 2008
    need codes for rcr3273
  • Anonymous Jul 19, 2008
    I need codes for my RCA 3-device snowbord universal remote for my Orion Tv and Orion VCR if some one has them or knows were to go to get them please let me know thank u [email protected]
  • meray12 Jul 22, 2008
    CODES
  • rickwardog Aug 13, 2008
    I have remote RC3273/RC3373. Does anyone know the code for this?
  • acoustyc Nov 04, 2008
    need codes for a sharp tv
  • Anonymous Nov 05, 2008
    I have the universal remote and a sharp tv and i dont know how to program it.. help!
  • billyace97 Dec 06, 2008
    I have the RCR3273 remote and a Sylvania tv, I have followed the directions in the instructions but I am unable to get the remote to work. Any constructive help would be appreiated.
  • Anonymous Apr 02, 2009
    dose any 1 no the code to this remote
  • Anonymous Apr 22, 2009
    i need to reprogram the remote
  • darlinbarb May 06, 2009
    I had the same problem, and after two days of searching, I found you. Thanks a million. I bought a 36" tv from someone, and it was without remote. I had an RCE723 old one, from the other smaller tv. My room-mated didn't even try to reprogram, just went out and bought a new one.
    I got mad, sent them both to their room (one is 51 male, the other 61 male) and said I will take care of this. I found you. It worked first try, and I told my other room-mates to take back their NEW universal one they bought, since they can't read the internet. Have a wonderful day.
    BARB, Arizona
  • marco58 May 11, 2010
    I have all the codes for the device but I am looking for the instructions using the codes.
    if you tell me the model i will provide you with the codes.
  • Anonymous Mar 13, 2014
    rca universal remote code maxent
  • Anonymous Mar 27, 2014
    lost my remote wondering if i can use a universal remote
  • 3 Answers
Answer for how to program the RCA RCR3273 3-DEVICE SNOWBOARD UNIVERSAL REMOTE:
Make sure the device is on. Hold down the tv (or whichever device you're trying to program) button and the power button simultaneously until the red light stays on solid. Then press the power button, it will flash one time, and keep pressing slowly, letting it flash until the device turns off. Then press the stop button...and it is programmed.
[email protected]
http://www.angelfire.com/journal/archer/index.html
Posted on Dec 18, 2007
  • Anonymous Nov 24, 2008
    Here's a minor edit of what I [Adult Swim] originally posted as a solution to this problem...
    Make sure the device [meaning the television, vcr, etc.] is on. Hold down the tv (or whichever device you're trying to program --- VERY MPORTANT: hold the device button down first} button and the power button simultaneously until the red light stays on solid. Then press the power button, it will flash one time, and then keep on pressing slowly, letting it flash until the device turns off. As soon as the device {tv, vcr, etc.} turns off, then press the stop {the button with a small square printed on it, right beloew the play button which has a right-pointing triangle printed on it} button ... and the remote is programmed for that particular device. If you want to program additional devices, just repeat the instructions above, but for the other device(s).
    Yet another edit [because of typos] of what I originally posted as a solution to this problem...
    Make sure that the device [meaning the television, vcr, etc.] is on. Hold down the tv (or whichever device you're trying to program --- VERY IMPORTANT: hold the device button down first) button and the power button simultaneously until the red light stays on solid. Then press the power button, it will flash one time, and then keep on pressing slowly, letting it flash until the device turns off. As soon as the device {tv, vcr, etc.} turns off, then press the stop {the button with a small square printed on it, right below the play button which has a right-pointing triangle printed on it} button ... and the remote is programmed for that particular device. If you want to program additional devices, just repeat the instructions above, but for the other device(s).
    This will work for this particular remote, with nearly all modern a/v appliances, however, it won't work with some older devices manufactured prior to maybe around 1990, and of course, it's possible that it might not work with some newer televisions, cable boxes, dvd players, etc. Be patient when cycling through the code list [pressing the power button again and again], because I think there may actually be several hundred codes in the remote! Hope it works for you.
    Also, thanks for all of the nice comments. I was having a really bad day when my remote somehow got deprogrammed, and like many folks, I had misplaced or perhaps thrown out altogether, my instruction booklet. So, because I didn't have an internet connection at the time, I stumbled a full two miles to the public library, where I used a public internet terminal to search, literally for a full hour before I found the answer somewhere buried deep within a tech-geek remote fansite. The RCA site was of no help at all, which is shameful. Convinced that I had found what I needed, I returned home, and was happy that it worked. Take care, everybody, because I know how frustrating a non-working remote can be. And that's my story. Heh.
Make sure the device is on. Hold down the tv (or whichever device your trying to program) button and the power button simultaneously until the red light stays on solid. Then press the power button, it will flash one time, and keep pressing slowly letting it flash until the device turns off. Then press the stop button...and it is programmed.
Posted on Jan 08, 2009
Here are remote codes and instructions. RCA is too lazy or incompetent to post the codes for this remote on their website.
http://rapidshare.com/files/87606013/remote_codes.zip.html
Posted on Jan 29, 2008
Go to www.rca.com/customerservice and you should find what you need there
Posted on Nov 14, 2007
I have the RCA RCR3273 3 DEVICE SNOWBOARD UNIVERSAL REMOTE and was wondering if anywhere online has codes for this remote? to a sharp tv
Posted on Sep 18, 2008
Wikianswers has the instructions for this-- it says:
hope it works for you-- it did for us!
Posted on May 27, 2009
My remote won`t work my game mode for my tv it`s a esa can someone help..........thanks i`m 12 years old
Posted on Apr 28, 2009
I have a sharp tv and i was wondering if any one out there knows the code and or how to program my sharp tv (1one4all)type of remote please help
Posted on Dec 17, 2008
I can't figure out how to program my remote// i have the rca universal remote and then a sharp tv.. what can i do?
Posted on Nov 05, 2008
Hey guys, I had the same problem trying to , find the code for the , control remote, but I did exactly what, "ADULT SWIM" wrote to do, and it works, press the tv button and the power button together, wow, it worked.
thanks guys!!!!!
Posted on Oct 31, 2008
Http://www.programremotecodes.com/
try this one. Hope it helps. I had one and I ended up taking it back because none of these codes work. Anyways, good luck to you because I have an old TV
Depasan
Posted on Oct 30, 2007
Thank you so much for the assistance. Your instructions worked great and my remote was not even this model. You Rock!!
Posted on Jun 16, 2008
6ya staff
SOURCE:
Need code isymphony tv using rca universal remote
RCA remote control have no set-up code for this TV brand. To select a proper universal remote control, you should know about the number of digits to its set-up codes. There are 3 digit, 4 digit, 5 digit, 2 digit and even single digit codes, to some brand devices. After confirming this, check the sites linked here. Both the sites have set-up code list and set-up procedure to many popular brand remote controls. Check which brand remote control has set-up code/s to your device brand, and buy that one according to availability? Brand name of the remote control isn't a matter, but it should have set-up codes in its code list, to the device brand you have.
Please note: Every new universal remote control will have set-up code list, and set-up procedure along with its pack. Never accept a remote control, that hasn't both of this. For more details about the set-up codes, visit the site http://electrohelponline.blogspot.com/ Check this site too. http://remotesearch.blogspot.com/ Universal remote controls are available at most of the electronic spare part selling shops. Visit some online sites too, which deals with electronic spare parts.
Oct 19, 2015 | iSymphony Televison & Video
I have an Ilive DVD/CD player. With no remote so I purchased a RCA rcr804bfdr/rcr804br series 4 in 1 universal remote control. I need the code to program this device.
RCA remote control have no set-up code to Ilive brand devices. To select a proper universal remote control, you should know about the number of digits to its set-up codes. There are 3 digit, 4 digit, 5 digit, 2 digit and even single digit codes, to some brand devices. After confirming this, check the sites linked here. Both the sites have set-up code list and set-up procedure to many popular brand remote controls. Check which brand remote control has set-up code/s to your device brand, and buy that one according to availability? Brand name of the remote control isn't a matter, but it should have set-up codes in its code list, to the device brand you have.
Aug 22, 2015 | RCA Televison & Video
Spongebob tv by emerson rca code
RCA remote have no set-up code to this brand TV. To select a proper universal remote control, you should know about the number of digits to its set-up codes. There are 3 digit, 4 digit, 5 digit, 2 digit and even single digit codes, to some brand devices. After confirming this, check the sites linked here. Both the sites have set-up code list and set-up procedure to many popular brand remote controls. Check which brand remote control has set-up code/s to your device brand, and buy that one according to availability? Brand name of the remote control isn't a matter, but it should have set-up codes in its code list, to the device brand you have.
Aug 08, 2015 | RCA Televison & Video
I just bought an rca universal remote for my KOSS KS 5109 I've searched everywhere for the codes for the RCA model RCRPS06GR I cannot find the codes for the KOSS system anywhere,
RCA URC has no set-up code for Koss brand devices. To select a proper universal remote control, you should know about the number of digits to its set-up codes. There are 3 digit, 4 digit, 5 digit, 2 digit and even single digit codes, to some brand devices. After confirming this, check the sites linked here. Both the sites have set-up code list and set-up procedure to many popular brand remote controls. Check which brand remote control has set-up code/s to your device brand, and buy that one according to availability.
Type in the "brand name only" of your device, in the search box [at the top right] of the display window and the Search will start at once as you type in, and will show you all the related posts. It will make surf easy.
May 14, 2015 | RCA Televison & Video
Will RCRN04BR RCA 4-device remote control work with xbox 360
No. This remote control has no setup codes for XBox.
Dec 18, 2012 | RCA Universal Remote Control
Apex codes
Hello
You are seeking codes with RCA systemlink-3 remote control to Apex TV. Unfortunately, there is no setup codes for Apex Tv with this remote control. It is very difficult to gat a remote control that has setup codes for Apex Tv.
Comcast On demand custom-3 universal remote control has codes for Apex.
Codes are :
0748, 0765, 0767
OK.
Oct 25, 2011 | RCA 3-Device Universal Remote
Needs codes rca remote
I'm not sure which remote and device you have. The header says a GE remote and the text says RCA remote. I'll provide locations for both types of remotes.
Try the following web site: http://remotefinder.rca.com/default.aspx?site=rca for RCA universal remotes. Enter the model of the remote as well as the brand and type of device to be controlled.
GE Universal remotes use either a three or four digit code. Find the code lists here: http://www.jascoproducts.com/support/universal-remote-codes.asp . Then determine if you have #24912 remote or which of the remote code lists that applies to your remote.
The code lists for any given remote will be limited to codes for devices released 6 months or more before the universal remote was programmed. If your device is newer than that date, the codes may not work.
I hope this helps.
Nov 20, 2010 | Universal Remote Control GE174Universal...
Cannot find remote code for panasonic TV/VCR combo for RCA remote
Here is a list of codes for your remote. Please follow any of the links below to get your codes.
Results 1 - 10 of about 324,000 for rca universal remote codes. (0.26 seconds)
Search Results
  1. RCA Universal Remote Control-Programming Codes RCA Universal Remote Control-Programming Codes. ... The remote may already be set up to operate your brand of TV, VCR, or Cable Box. ...
    www.thompsontv.com/rcarc.html - 33k - Cached - Similar pages -
  2. How to Program an RCA Universal Remote Without a "Code Search ... wikiHow article about How to Program an RCA Universal Remote Without a.
    www.wikihow.com/Program-an-RCA-Universal-Remote-Without-a-%22Code-Search%22-Button - 42k - Cached - Similar pages -
  3. Universal Remote Control Codes Codes and links for a number of universal remote controls, including Sony, RCA, Memorex, Radio Shack, One For All and more.
    www.xdiv.com/remotes/ - 73k - Cached - Similar pages -
May 05, 2009 | RCA Universal Remote 3 Device Remote...
Program TV Remote:
Turn on tv
Press and hold TV button
Enter code 1060 use one from below
Release TV button
Press Power
If TV turns off then the code is set, if not try another code from this list:
1004
1067
1075
1082
1164
1014
1061
1072
1076
1083
1166
1046
1062
1073
1077
1112
1176
1051
1066
1074
1078
1136
Apr 18, 2008 | Televison & Video
Televison & Video Logo
8,296 people viewed this question
Top Televison & Video Experts
Marvin
Marvin
