Cars & Trucks Logo
A
Anonymous Posted on Dec 04, 2013
How do i fix 2014 nissan altima radio song and title display
Kelsey A
Level 1:
  • Contributor 1 Answer
  • Posted on May 28, 2014
Kelsey A
Contributor
Level 1:
Answers
Questions
0
Helped
3256
Points
0
What do you mean by "fix" the display, is it not showing it? If so- my Nissan Altima has not been displaying Sirius XM Title and Artist for months. After much searching of the internet, I finally found an answer that worked! Just be sure to write down your radio/sirius presets before you reset the radio - it'll clear them all (and the time). The answer is here- http://incodesystems.com/Troubleshoot/Cars/RadioInitialize.htm
4 Related Answers
Anonymous
  • 3301 Answers
  • Posted on Aug 26, 2011
SOURCE: The radio in my new Venza doesn't display the
normally if the title is more than 12 letters it will end there, some go more, don't know why ,, sometimes it won't be the song title just the artist
Bill Hackett
  • 383 Answers
  • Posted on Apr 23, 2009
SOURCE: how do I fix a radio light that went out?
jackxlong: I wish I could give you an answer you would like, but it is the only one I know.
Unfortunately, Nissan has no service procedures for actual internal repairs to the radio. The only thing you can do is remove it and have it repaired at a shop which services audio equipment.
It is sometimes cheaper to buy a used unit from a salvage yard than it is the have your repaired. Often the minimum charge is more than what you can buy a used unit for.
Look into it before doing anything. Check with regular automotive audio shops, they may have "Take out" units they will sell cheap and/or be able to fix yours.
Good Luck.
Anonymous
  • 25 Answers
  • Posted on May 10, 2009
SOURCE: Pioneer radio won't play song titles!
Some places like Best Buy offer a disk that you put into the changer and it will reset the deck.
Anonymous
  • 977 Answers
  • Posted on Jul 16, 2011
SOURCE: My radio for my 2002
it could be a problem with the antenna lead not plugged into the radio or the wire has a break in it or it could be the antenna is faulty....hope this helps......cheers.
2014 Nissan Altima. How to unmute audio for Bluetooth please?
The 2015 Nissan Altima does not have a mute button for the Audio system. To unmute the Audio system You will have to turn the volume knob clockwise. If this does not fix the problems with the Audio in the vehicle You can try and attempt a full reset of the radio in Your car. To do this You will turn the ignition key to the "on" position and turn Your radio on, wait ten seconds and then turn Your radio off. Depress the radio power button again and wait for reset. Alternatively, enter Your dealer provided radio code to reset. You can also check to see if You had a call and if You did not press the "call hang up" button on the steering wheel while not on a call it could mute the radio so press it again to un mute it.
I have a 2014 nissan altima...the transmission was screwy, got reprogrammed. still doesn't work...now what?
2014 nissan altima
I think you should try this website link that I have attached. It helps you repair your vehicle easily without more help. Ask the girl in chat at the bottom of the page
Radio/Nav is malfunctioning; unresponsive, shuts down/reboots, slow to react to inputs
The only thing that you can do is remove the unit and send it out to a factory approved repair shop, that is it no other choices.
6helpful
2003 Nissan Altima radio still works but the clock/radio station display went blank...HELP
Just fixed this myself today. There is a surface mount component (resistor I believe) that has come off inside the radio. It was labelled 180 on my radio. It is on the circuit board actually inside the radio, not the dispaly button panel, on the left side behind the volume know. I soldered it back on and now the display works again.
How do i get the title of the station and the title of the song back running across my radio screen? the message button doen't fix the problem...
How about a display button usual on most new after market radios anyway the display button controls what you see on the screen
Battery replaced - radio dead, and i don't have the code. no manuals, only a car title. how can i get my radio back?
take your car to nissan and log book(registion book) and for a small fee you will get a the code and how to put it in
2answers
Top Cars & Trucks Experts
ZJ Limited
ZJ Limited
john h
Arnie Burke
Arnie Burke
Are you a Car and Truck Expert? Answer questions, earn points and help others
