Question about Cuisinart DLC-1 Mini-Prep Food Processor
Will not turn on
I have a mini-prep and I plugged it in and it turned on.  However, once I added food and put the lid on, it will not turn on; nothing happens. I let it sit for a while, and tried again and it turned on, so I added one piece of onion, and again, it would not turn on.  Any help you can offer would be great!!!!
6ya staff
SOURCE:
oldnovii
Jeffrey Pemberton
  • 667 Answers
SOURCE: Food Processor
Here is the link for your manual. Enjoy! http://www.cuisinart.com/share/man/404_man.pdf
Posted on Mar 15, 2008
ThaMp3Doctor
ThaMp3Doctor
  • 8597 Answers
SOURCE: I have all the accessories to juice an orange but
I would just remove and replace the work bowl, and then reposition the strainer, etc again. I don't know what the magic is, but if I just put everything back in palce exactly as the user manual lays out, I can always get it to work again.
-Tha Mp3 Doctor
Posted on Mar 20, 2009
ThaMp3Doctor
ThaMp3Doctor
  • 8597 Answers
SOURCE: Lid stuck on bowl of my Cuisinart Mini Prep Plus.
Generally they twist off, but on the DLC-2, if the lid won't come off, a replacement bowl and lid is around $18.00
Btles
  • 172 Answers
SOURCE: Cuisinart Mini Prep - just stopped working.
Check for and test any internal inline fuses.
Posted on Aug 12, 2009
ThaMp3Doctor
ThaMp3Doctor
  • 8597 Answers
SOURCE: I Cuisanart mini prep and removed the bowl, lid,
Make sure the tab on the lid is making contact with the "tower" in the back and that the work bowl is locked properly into place so that the plastic tabs show on each side toward the bottom of the work bowl.
Posted on Sep 29, 2009
My Cuisinart mini food processor has worked beautifully. Now the blades are turning but nothing is being chopped or ground. Thanks!
the drive connection for the blades has probably stripped out and not driving the blades when there is work to do
Nov 08, 2015 | Cuisinart DLC-2 Mini Prep Plus Food...
My cuisinart DLC-1ss will not start once plugged in.
The bowl must be locked in the correct position for the unit to turn on.
Remove the bowl, place on unit and rotate into place.
Oct 04, 2010 | Cuisinart DLC-1SS Mini Prep 2.63 Cups Food...
It won't turn on
The work bowl and lid must be locked together in a specific order or else the processor will act dead. If your DFP-3 has a "tower" on the back, make sure the tab on the lid connects to this tower. If your model does not have a tower, call Cuisinart to verify the correct assembly - 1-800-726-0190
Aug 16, 2009 | Cuisinart DFP-3 Handy Prep 3 Cups Food...
Aug 12, 2009 | Cuisinart DLC-2 Mini Prep Plus Food...
Can't get cuisenart pro 11 to start
I am assuming you have a DLC-8S Pro Custom 11, and not another Cuisinart food processor.
Remove the work bowl and all other parts completely from base.
Plug the base in, and turn it on.
Use a pen to press in the dark grey or black button on top of the base.
If you hear a spinning or other noise, the motor is still good.
Now that you have verified that the motor is good:
Put each work bowl piece on one at a time - if you don't out it on one at a time, it will not lock in properly.
Put work bowl on with work bowl handle facing front, make sure bowl locks.
Put lid on with hollow feed tube facing the back of the food processor.
Put pusher sleeve into lid's feed tube, with sliding lock switch facing the front of the food processor.
You should now be good to go.
Apr 07, 2009 | Cuisinart DLC-2011 PowerPrep Plus Food...
None of the buttons work on my Power Prep Pulse 11-CUP
Remove the work bowl from the base of the food processor, and separate the bowl, lid, and pusher sleeve.
Plug the base into the wall outlet, turn the food processor ON, and then use a pen to press in the dark grey or black button on top of the base of the food processor - if you hear some kind of noise, then your motor is still good.
Put the work bowl on first, with the handle facing the front of the food processor.
Put the lid on, with the hollow feed tube facing the back of the processor.
Put the pusher sleeve in the lid, with the sliding lock switch facing the front of the processor.
Your processor should now turn on.
If your food processor still does not turn on, call Cuisinart and see if you are eligible for an in-warranty repair - it has a 3-year warranty.
-Tha Mp3 Doctor (also loves Cuisinart)
Mar 23, 2009 | Cuisinart DLC-8S Pro Custom Food Processor
Dec 24, 2008 | Cuisinart DLC-2 Mini Prep Plus Food...
Cuisinart prep 11 Plus won't run.
Remove the work bowl completely and separate the work bowl, lid and pusher sleeve. Plug the base into the wall outlet and press the on switch. Use a pen to depress the dark grey or black button on top of the base of the processor. If you don't hear a sound, then call Cuisinart and get it repaired. If you do hear a sound:
1. Put the work bowl on first, making sure the handle is facing front
2. Put the lid on, making sure the hollow feed tube is facing the back of the food processor
3. Put the pusher sleeve in, making sure the sliding lock switch faces toward the front of the processor
Turn the machine on - it should now be working
-Tha Mp3 Doctor
Cuisinart DLC-1 Mini-Prep Food Processor Logo
161 people viewed this question
Top Cuisinart Food Processors Experts
Colin Stickland
Colin Stickland
Bruce Showalter
Are you a Cuisinart Food Processor Expert? Answer questions, earn points and help others
