Model u5140 900 vacum got a new front wheel support but I cant get the axle and wheels off the old part. How do you get the front wheels off?
SOURCE: Hoover upright vacuum information
cant help with manual but if i may why would u take it apart theres not much to service but to take the belt off turn the machine over and down by the roller there are a few screws take them out the cover should come off and thats it
SOURCE: how to fix wheels on hoover vaccum cleaner
i cant get the back wheels off my mach 3 hoover vacuum can anyone help?
SOURCE: how to install front wheels
Please be sure to unplug the vacuum before doing this. Pull the sides from top cover on the floor portion (Where the light is) and it pops right off. After the cover is off, step on the lever to tilt the handle back like you are going to sweep. Lay the handle all the way down to the floor to raise the bottom of the vacuum somewhat so you can reach under it. You should be able to push up on the front wheel assembly, it should be very loose. If you look on the top of the vacuum where you removed the cover you should see a clip that moves when you push up on the wheels. Carefully squeeze the clip to push it past the opening and the front wheel assembly should drop down to make removal possible. This works on the Breath Easy model.
SOURCE: hoover front wheels replacement
on the wheel assembly you will see on each end the studs with the flat ends on them,slide the studs in the slots and fold wheels forward and push in.in the middle at the front of the wheels you will see a flat catch ,push it up into the base right behind the brush roller and it will snap in
SOURCE: need instructions to replace hoover U5757-900 belt
install the belt on the motor shaft first by sliding it sideways between the shaft and housing. then install on the brushroll and stretch in place
