Televison & Video Logo
Question about Lite On Televison & Video
Power supply for liteon dda110
I have a liteon dda110 for which the power supply board has failed. With case off, I can see a 220ac supply at input, but zero at all the DC outputs running to the main PCB. No fuse on PS board and no sign of leaking caps. Any ideas?
5 Related Answers
night71
Lyle Siemens
  • 328 Answers
SOURCE: POWER OF 5V IS THERE, 9V IS THERE, GOES INTO PC BOARD UNDER DVD MECH.
Since I don't know what model it is, I am going for a shot in the dark. I found a place that has service manuals for Daewoo for free. If none relate to your DVD player, please give me the model number and I may find one for you.
http://www.eserviceinfo.com/repair_tips_database/Daewoo_001.html
Posted on Nov 10, 2007
Anonymous
SOURCE: FAULTY POWER SUPPLY FOR LITE ON PS -5251-2DS
when connected the AC power , no DC voltage reading from the p.s.
what to do?
how can i turn it on?
Posted on Nov 24, 2008
Anonymous
  • 555 Answers
SOURCE: computer does not turn on
you can try your power supply if it works by jumpering its pin. try to insert copper wire in pin 11 and connect it to pin 12. and turn o your power supply. But if it won't works then used tester and test its circuit boards particularly  is capacitors, resistors and even the transformer inside the power supply. Or if you can't make it then you can call a technician either in computer or electrical to test your power supply if it still working or not. In that wy can be sure in making decision if its really your power supply got problem or not.
Thanks
Posted on Jun 26, 2009
Anonymous
SOURCE: Where to replace burnt out PCB.
Unfortunatly I have the same problem but it seems the main MOSFET bolted to the heatsink (SSS4N60B) in the high voltage section has failed which I suspect has led to the destruction of the capacitors. I lost the 5v and 12v supply which happen to have the damaged caps in there circuit. See how you go but I'd be having a close look at that MOSFET as well.
Posted on Aug 29, 2009
Anonymous
  • 832 Answers
SOURCE: I have a Liteon PS-5301-08HA in my HP desktop. I
Replace it with a higher watt capacity, say 400 or 500
watts rating, Choose the one that can be mounted and fit in your PC fit without any revision to be done.
Posted on Nov 14, 2009
1helpful
A manual for a Liteon DDA110 dvd recorder
Hi there I just found this on google. Try it.
www.retrevo.com > ... > LiteOn DVD Players Manuals > LiteOn DD-A110Cached - Similar
Blows fuse
If your Liteon 32276 power supply board is causing blown fuses, there are a number of things to try.
Try plugging into a different outlet in your house to see if the result is the same.If the result is the same, you may need to replace your liteon 32276 power supply board as it may be defective.
Power supply Blown by 220AC
Hello
There may have a doubled input voltage applied to amp boards at least for a second. It cannot be predicted whether it has damaged any more components or not. It can be confirimed only after a new transformer replacement. OK.
GERICOM laptop power charger - Liteon model PA-1900-005
yes this is common rating for laptop any laptop adapter can be replaced see the output voltage and current of another adapter matching . if connector is not matching then solder the matching connector
1helpful
Cannot locate the fuse in the liteon power supply
The fuse is internal, and soldered to the circuit board. It can be replaced by soldering - an old-timers trick is to get a new fuse (with pig-tails) and just solder in parallel with the old - no removal needed.
1helpful
2answers
Turning on a Liteon power supply without being hooked up to compu
On the main plug there are several black wires(ground), and one green wire. Jumper any black wire to the green wire and there you go.
1helpful
2answers
Hooking up a Liteon 24X DVDrw burner
The SATA drive is to be used with a motherboard that supports SATA 1 or 2.
If you have a board that supports SATA, you should also have a power supply that supports SATA.
The 7 pin connector is for data. the other connector is for power.
Hope this has helped you.
P.S. Their are conversion kits for the power supply if yours does not support SATA but your board is something else all together.
Get back to me with the make a model number of the PC and I will check if you want.
2helpful
5answers
What voltage is the dc adapter?
You will need at least a 4 amp rated regulated 12 Volt power supply.
These are commercialy available from most electronics parts suppliers.
They come on a circuit board. You can mount it in your own case and
use the original Viewsonic wire end. If you do a google search for 12
volt reglated power supplies you should find many of these.
However, with a second-hand Sprint AC adapter with 3A,
12v adapter, the screen blinks on and off
intermittently. Obviously there is some difference here between a class
2 adapter and a power supply box.
1helpful
4answers
1501 power supply
The screen comes standard with a LiteOn power supply, 12v 3.3amp
Top Lite On Televison & Video Experts
Jaime Hernandez
Colin Stickland
Colin Stickland
Are you a Lite On Televison and Video Expert? Answer questions, earn points and help others
