RTO W4 A.O Smith Gas Hot Water Heater Draft Inducer Logo
Question about RTO W4 A.O Smith Gas Hot Water Heater Draft Inducer
Ao smith water heater.after i get hot water the polit goes out ,i could light it again but only when it ask for hot water,after it heats up it goes out again.
Model gcv50100 promax
Posted by teddy on
5 Related Answers
Anonymous
SOURCE: Pilot light going out randomly AO Smith Promax GCV 50 100 Gas HW
After my previous water heater failed after 31 years, I had a 30-gallon A. O. Smith Promax gas water heater installed on October 30, 2007. On November 17, after 19 days, the pilot light went out. For the next seven months, the pilot light continued to fail and had to be relit.
The pilot failed sometimes every few days, sometimes every day, sometimes four times a day or more.
Eventually, I had to relight the pilot light every time we needed hot water. The plumber who installed the Promax returned five separate times to try and fix it, without success. An A. O. Smith Authorized Technician tried and also failed to fix it. To help find the problem, I installed a camera at the heater viewing window, and videotaped the pilot failing four times. No one looked at the tapes.
I began to think that this water heater must be pretty bad if an experienced plumber couldn’t fix it after five tries, and an A. O. Smith Authorized Technician, who works on nothing but A. O. Smith products, also could not get it to work.
Over seven months, I had to relight the pilot 63 times. At 10-15 minutes per relight (according to A. O. Smith instructions), this comes to a total of between 10-16 hours I spent lighting this heater. I can assure you that having to lay on your stomach at all hours of the day and night, in a cold and dark cellar, is not a pleasant job for an old man.
A. O. Smith, and the Factory Authorized Service Technician (who is paid by A. O. Smith) blame me for the Promax failure and refuse to refund my money. They say (without any tests or proof) that water vapor coming through the dirt floor in my cellar causes excess humidity which clogs the heater’s flame arrestor, disrupts the air flow to the heater, and puts out the pilot flame.
In 2003, the Government got into the water heater business. It required all water heater manufacturers to fit a ’flame arrestor’ into water heaters. A flame arrestor prevents the burner flame inside the heater from igniting flammable vapors outside of the heater. All heater manufacturers were allowed to come up with their own design of flame arrestor.
I learned from some plumbing websites that the real problem with the Promax may not be
my cellar, but the design of its flame arrestor. All incoming air for the heater’s operation must pass through the flame arrestor. The Promax uses a flame arrestor made from a Corderite ceramic disc. This ceramic disc is about the size of a saucer, so limits the air coming into the heater. In addition, the openings in the disc itself are small, further restricting air flow.
Aside from any design problem with the Promax, there are several reasons why A. O. Smith blaming me for the Promax failure is nonsense.
I was given no warning before purchasing the Promax, either from the plumber or A. O. Smith, that humidity was a limiting factor for the operation of this heater. No one told me that this heater needed a certain humidity range in order to work, much less what the humidity range was supposed to be. If I had known beforehand of a potential problem,
I would not have bought the Promax heater.
The excess humidity conclusion is not supported by statements in A. O. Smith’s own Instruction Manual (#184165-003) and Service Handbook (#TC-049RC). In these manuals, the word ‘humid’ is mentioned only once in 93 pages, and then only as an indication of tank leakage, not as a cause of pilot flame failure. These manuals are available on A. O. Smith’s website http://
www.hotwater.com/lit.html
Saying that my cellar is too humid, does not make it so. During December 2008-January 2009, I tested the relative humidity in my cellar using a Honeywell hygrometer. For these two months, the relative humidity was in a range from 51%-65%, staying mostly in the mid-50s.
A 30%-65% range for occupied areas is recommended by The American Society of Heating, Refrigerating and Air-Conditioning Engineers (ASHRAE thermal comfort standard for Human Occupancy, Standard 62.1-2004). Their chart can be seen at http://www.ccohs.ca/oshanswers/phys_agents/thermal_comfort.html.
This means that even though my family doesn’t actually ‘occupy’ our cellar, the relative humidity there is within ASHRAE standards. This normal reading is more significant in that during January 2009 we had four times as much snow (i.e. more moisture thus more humidity) than during the same period in 2008 when the Promax was installed. In other words, during January 2008, the humidity level in my cellar was probably even lower.
I also tested the wooden beams in my cellar with an Extech moisture meter. All the wood tested normal at 20% or less moisture. My home was built in 1924, so these normal readings are after 85 years of supposedly excess humidity.
These tests show that my cellar is not ‘too humid’ as A. O. Smith maintains and therefore is not likely to be the cause of their product’s failure.
My films of the Promax pilot light failure show that the pilot fails in several ways; it goes out by itself, or when the burner tries to go on, or when the burner is lit and then turns off. A. O. Smith’s lack of air explanation for the pilot failure seems suspect considering that the burner itself, which must require thousands of times the air the pilot does, had no trouble staying lit (once the pilot was lit) during a heating cycle.
The solution for pilot flame outages, A. O. Smith’s Legal Department says, is to clean (vacuum) their ceramic disc flame arrestor top and bottom routinely. To do this the burner must be removed, not a job the average customer can or would want to do.
Some plumbers state (see links below) that it is impossible to properly clean the bottom of this ceramic disc at all, as that part is nearly inaccessible. In any case, calling a plumber ‘routinely’ (every three months? every month?) is expensive and irritating, considering that your old heater may have lasted for decades without any attention at all.
http://weilhammerplumbing.com/products/
http://www.weilhammerplumbing.com/galleryi/
I believe that most people would consider it intolerable if a brand-new car failed to start 63 times in seven months. After experiencing similar inconvenience, not to mention cold water, I replaced the Promax with a Bradford-White heater (my choice and in spite of the plumber‘s objections) on May 24, 2008.
The Bradford-White has a stainless steel flame arrestor, the full diameter of the heater, and lets in plenty of air. The Bradford-White has now been installed for a much longer time than the Promax, and has worked perfectly in the exact same location, in the exact same ‘humid’ conditions.
I am out almost $1,000 for A. O. Smith’s measly 30-gallon gas water heater.
Posted on Dec 12, 2009
motor1258
Mike Butler
  • 6674 Answers
SOURCE: G4-7 atwood water heater lights great, heats water
Sounds like the burner flame may be too strong (jumping out from burner tube) . Some people think the louder the better, but that is not correct. When burner shuts down like that, it has a tendency to snuff out pilot as well. Adjust your air shutter at burner so that the flame is a nice blue, or with just a hint of orange/yellow at the tip. Whatever setting that keeps the flame solid from burner tube, and not a big gap between tube and flame. Signs of soot (black) up the cover, or side of trailer means it's running too rich, and you've gone too far thus needs more air. Keeping the flame blue but still right out of the burner, actually heats better, is quieter, and should eliminate that pilot getting snuffed out. Pilot should also be a nice blue flame as well. There may be a problem with positioning of the burner tube as well, but doubtful if it has been running well in that position before. Let me know what happens.
Posted on May 13, 2010
Anonymous
SOURCE: MY Atwood 6 gallon water heater will start heating
I have an Atwood GCA6AA Combination 110VAC/LP gas w/ electronic ignition. Manufactured 5/13/08. It was operated without being full of water. The 110V still heats but the gas operation appears to be locked out. I have 12VDC at the control panel. I have jumpered the thermal cut-off to no avail. I have 12VDC to the circuit board thru the BRN 3 wire. Is there a way to reset the ECO switch? Is the pricey circuit board the next step.?
Thanks,
Joel
Posted on Jul 22, 2010
motor1258
Mike Butler
  • 6674 Answers
SOURCE: Atwood 10 gallon H2O heater-
I'd check that ECO and thermostat discs are making contact properly with tank.Just peel back foam cover on outside of tank that has ECO and THERM marked on it. If they are installed correctly, replace them.
Posted on Sep 21, 2010
motor1258
Mike Butler
  • 6674 Answers
SOURCE: I have a 6 gallon
Your on right track. When this happens and small flame still there, pull wire(s) off at gas valve, or test for voltage from ECO to gas valve. No voltage, then there should be no gas. Change gas valve.
Posted on Oct 20, 2010
Testimonial: "Changed the gas valve, now heater works as it should, No fumes and no flame after shutoff."
How do I set ao smith pro max model ect 52 on vacation mode
No vacation mode in this heater. I have used this for last 5 years.
AO SMITH VOLTEX ERROR CODE ELEMENT ON HEAT PUMP FAULT ON SCREEN
Copy following link
http://waterheatertimer.org/pdf/AO-Smith-heat-pump-service-manual-321547.pdf
Contact AO Smith for qualified technician in area.
Don't buy expensive water heaters.
Gene
h
If you need further help, I’m available over the phone at https://www.6ya.com/expert/gene_9f0ef4df2f9897e7
My water heater heats everything except my lower shower
Let's walk our way thru this one: I assume you have an upstairs shower, and a downstairs shower?-- Are you able to follow the pipes coming out of the Hot Water Heater?-- Can you trace where the pipes to the upstairs shower go?-- And what about the pipes to the lower shower? -- Do they BOTH come off the HOT water pipes coming out of the top of the HW Heater?
A big help in tracing pipes, is by having the hot water run in the Shower that is getting HOT water-- Feel the HOT! pipe?-- Now-- shut that water off, and go to the lower shower-- When it is running, can you hear water flowing out of the pipes at the top of the Hot Water Tanks?-- or do you feel Cold water moving-- Can you travels where it is flowing from? Get back with me, and tell me what you are feeling, and hearing-- Mack B
No hot water - the light shows red. It has had problem in the past months but cutting the power off and back on seemed to reboot the computer. This time the light stays red.
Before calling service technician:
Click following link, the click product, then scroll to page bottom to tab that offers technical literature, and download service manual and operation manual.
http://www.hotwater.com/water-heaters/residential/hybrid/
Read the required installation and maintenance protocol to see if air filter has been cleaned regularly, or the condenser coil might be dirty.
Required maintenance can be done by service tech recommended by AO Smith.
Contact AO Smith to find trained person, and next time, do not install expensive water heater since all savings disappear with service issues.
Gene
h
Does the pilot light always stay lit on this water
Many water heaters today are pilotless.
Call manufacturer with model and serial number
Gene.
1helpful
AO Smith GPS 75 200 not working
Copy following link for troubleshoot service manuals by type of gas control valve, including instructions for replacing gas control valve:
http://waterheatertimer.org/How-to-troubleshoot-gas-water-heater.html#intellivent
http://www.hotwater.com/lit/training/320988-000.pdf
Perform the required maintenance, and catch unit up to date, and replace gas control,,, might be best to call plumber.
The intellivent gas control valve is removed completely from tank, so tank must be drained.
1helpful
I have an A. O. Smith Model FPSH 40-261 hot water heater. It won't heat water. there is a green light on the control flashing. What does it mean?
AO Smith uses the Honeywell ICON gas valve with green indicator light.
Some models use White Rodgers Intellivent with a row of indicator lights.
The gas control blinks the error code:
Open following links to identify gas control thermostat and read possible error codes:
http://waterheatertimer.org/pdf/Honeywell-Gas-Valve-LED-Codes-2000.pdf
http://waterheatertimer.org/BW.html#Temp
http://waterheatertimer.org/How-to-adjust-water-heater-temperature.html#intelli
Burner didn't ignite on my AO Smith model FXGT/PGXT
Unless your AO is a high recover it will take a while for it to fill up with the water that you have used then reheat the water in the tank.
Top RTO Water Heaters Experts
Mike
David Shaub
Are you a RTO Water Heater Expert? Answer questions, earn points and help others
