Question about Schlage BE365-CAM BE365CAM613 Oil Rubbed Bronze Electronic Security Keypad
How to change baterry o schlage be365
We push schlage green button and are able to open the door by turning the deadbolt and not enter our code when we lock from the inside we can still open the door the same way
Posted by Becki Ehlers on
  • 6,182 Answers
To change the battery on the BE365, you need to remove the inside cover by removing the two screws (one above and one below the deadbolt knob). Be careful to tuck the wires inside the lock so that they will not be crimped when you put the cover back on.
Do you here a beep and see a flashing light? Usually if pressing the Schlage button unlocks the deadbolt, your installation was done improperly. The cam on the base plate must be vertical and the bolt must be correctly installed.
You will always be able to lock and unlock the deadbolt with the inside thumb knob.
I hope this helps.
Posted on Dec 04, 2013
3 Related Answers
Anonymous
SOURCE: how to change the battery on my BE365-CAM-716 Schlage Keypad Deadbolt
Problem fixed by having my wife look it up on the Schlage website. The deadbolt has a flash memory so your combinations and codes will not be lost when the batteries are changed.
Posted on Sep 30, 2008
Coaltowner
  • 963 Answers
SOURCE: Does my Schlage BE365-CAM BE365CAM505
Sort of. The lock has what is called the "turnlock" feature. When enabled, you have to only push the Schlage button, then manually turn the "dial". When disabled, you have to enter the user code, then turn the dial. So either way, you still have to turn the dial.
To enable/disable this feature, enter your Programming Code --press Schlage button--press 7
Each time you do this, you toggle between enabled and disabled.
"How can I program my electronic keypad lock when the instructions with the Programming Code have been lost?"
The back plate of the keypad side of the lock on the exterior of the door has a sticker which includes the serial number, six digit programming code and two pre-programmed four digit user codes. The lock must be disassembled to a point the exterior of the lock can be pulled away from the door and the information on the sticker made note of.
Complete installation & programming instructions can be found here:
http://consumer.schlage.com/Project%20Documents/P515-858.pdf
Notice that the above is a .pdf filetype. That means that you need to have Adobe Reader or similar installed on your computer to view it. So if you are unable to view the file, download (for free) and install Adobe Reader first. You can get it here:
http://get.adobe.com/reader/
Videos for installing and programming can be found on this page:
http://consumer.schlage.com/Service-Support/Pages/InstructionandManuals.aspx
Scroll down and find them under the heading Electronic Security-Keypad Deadbolt BE365
Posted on Aug 12, 2011
Coaltowner
  • 963 Answers
SOURCE: I have a BE365 Lock on my door. When I go to lock
How do I enable the alternative setting (Code Turn)? (BE365 Deadbolt only)
1.) Enter your current 6-digit programming code
2.) Push the button
3.) Press 7 on your keypad
Posted on Nov 09, 2011
Shlage keypad dead bolt unlocks when you press the
Does my Schlage BE365-CAM BE365CAM505 have a feature that allows it to automatically lock the deadbolt without having to enter code and turn the dial?
Sort of. The lock has what is called the "turnlock" feature. When enabled, you have to only push the Schlage button, then manually turn the dial. When disabled, you have to enter the user code, then turn the dial.
To enable/disable this feature, enter your Programming Code--press the Schlage button--Press 7.
Scroll down and find them under the heading Electronic Security--Keypad deadbolt 365
Aug 31, 2012 | Schlage Camelot Deadbolt Keypad, Satin...
Door will unlock without entering code
"Does my Schlage BE365-CAM BE365CAM505 have a feature that allows it to automatically lock the deadbolt without having to enter code and turn the dial? "
Feb 15, 2012 | Schlage BE365-PLY BE365PLY626 Satin...
Can't push one button to lock anymore
Good luck-and please provide feedback if this helps!
Aug 12, 2011 | Schlage BE365-PLY BE365PLY626 Satin...
Aug 11, 2011 | Schlage BE365-CAM BE365CAM505 Lifetime...
I have spent over an hour looking for information on how to set a code for my Schlage BE365 CAM 619 keyless access deadbolt. I want a very SIMPLE explanation. Don't tell me to go to the Schlage web...
First make sure you have a fresh new battery installed
Next if you feel you have fiddled with it so much you can reset the lock to the factory default settings, to do this
1.Disconnect the Battery
2. Press and hold the Schlage Button while reconnecting the battery
However proceed before resulting to a reset and see if you are sucessful.
There are preprogrammed user codes already programmed into the unit
These two USER CODES (UC) are on the Yellow Sticker and on the Installation documents that came with the lock. Also the 6 Digit PROGRAMMING CODE (PC) is listed in the same location.
Assuming the lock was installed correctly and tested for correct operation.. proceed...
First.. I agree with you about the instructions.. many places they use the word "press" when they should have used the word "enter".. or phrase.. "enter the user code by pressing the corrosponding numbers".. however..
With the door open test the lock function
Press the Schlage button.. this should extend the bolt
Next Enter one of the two supplied preprogrammed user code (a) or (b) and rotate the thumbturn away from the door edge (generally to your left or counter clockwise) This should retract the bolt.
To Enter a New USER CODE (UC)
1.Enter the 6 Digit Programming Code (PC) via the key pad
2.The Schlage button will glow Orange
3.Press and release 1 on the keypad
4.Enter your new/desired 4 Digit USER CODE (UC) via the keypad
5.Enter the new/desired 4 Digit USER CODE (UC) via the keypad again (yes a second time)
The Schlage button should flash green.. signalling the program was sucessful
Repeat the lock function test using the new User Code (UC)
Make sure you write the new UC number down.
This lock will store up to 19 UC codes.
Good Luck!
Mar 11, 2011 | Schlage BE365-CAM BE365CAM619 Satin...
Hi does this lock auto lock like the one with a handel does?
To enable/disable this feature, enter your Programming Code--press the Schlage butt0n--Press 7.
Nov 23, 2010 | Schlage BE365-CAM BE365CAM505 Lifetime...
I have a BE365 Lock on my door. When I go to lock the door it wants the code punched in and the knob turned. When i unlock it, it just wants the schlage button pushed and knob turned. HELP
2.) Push the button
Nov 16, 2010 | Schlage BE365-PLY BE365PLY626 Satin...
I push scglage button and unlocks the lock
http://consumer.schlage.com/Service-Support/Pages/InstallationTroubleshooting.aspx#5
Why can my electronic keypad deadbolt (BE365) be unlocked without a four digit user code when I press the "Schlage" button?This is most likely due to an installation error. When the lock is assembled on the door, two steps of the installation must be followed to insure proper operation. The deadbolt must be installed in the door edge with the bolt retracted, and the gray plastic cam on the interior mounting plate, through which the flat metal driver bar passes, must be pointed down (see below). The gray plastic cam has a triangle embossed on the end opposite the driver bar which should align with a matching triangle on the orange plastic cover plate below. These instructions are also embossed on the orange plastic plate.
Troubleshooting Image 2
If the cam is improperly aligned, the lock must be disassembled to a point where, with the bolt retracted, the cam can be turned to the correct position without moving the bolt. This will require withdrawing the flat driver bar completely from the cam before turning the cam. The driver bar will then pass through the cam at a forty-five degree angle when the lock is reassembled.
Sep 07, 2010 | Schlage BE365-PLY BE365PLY626 Satin...
How to change the battery on my BE365-CAM-716 Schlage Keypad Deadbolt
Sep 21, 2008 | Schlage BE365-CAM BE365CAM613 Oil Rubbed...
Schlage BE365-CAM  BE365CAM613 Oil Rubbed Bronze Electronic Security Keypad Logo
471 people viewed this question
Top Schlage Locks & Locksmithing Experts
JOHN LAPIER
Mike
Are you a Schlage Lock and Locksmithing Expert? Answer questions, earn points and help others
