how you wire it depends on your amp, I assume that the sub is a 4ohm DVC from what you have provided.
Parallel:
If you have an amp that can handle a 2ohm stable load you can connect one voice coil + and - to the amp and then run wires across the sub to the other side + to + and - to -
Series:
If your amp won't support 2 ohm you have to run it at 8ohm, to do this you connect from the amp to one + and to the - on the other voice coil on the sub, you then run a single wire between the + and - terminals .
Below are some images to help
Parallel (2ohms)
Series:
