Question about Ge Medical Systems Ge Marquette Mac 1200 Interpretive Ecg
I have a Marquette Max-1 that loses date/time when powered down. Is there a backup battery/capacitor?
Posted by keith westhoff on
SysAdminGuru
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 61 Answers
Replace the backup battery usually found on the back or near the bottom near a clip.
Posted on Dec 03, 2013
Testimonial: "This unit is a Max-1, not a Mac 1200. I appologize if there was any confusion. Is your answer still applicable for the Max-1?"
  • SysAdminGuru
    SysAdminGuru Dec 03, 2013
    Sorry I think that one is older and is on the mainboard, so you'd have to open her up and find the battery. not as familiar with that one though.
  • keith westhoff
    keith westhoff Dec 03, 2013
    no prob. thanx
Hello, I have an GE Marquette Max 1 stress system and it loses time and date. Could someone help me find the time keeper? Thanks in advance
These usually have a button cell battery to hold the time when its powered off. This backup battery is usually found on the back or underside but may also be inside.
Feb 13, 2018 | GE Medical
Date 01/31/14
Does it keep losing the date when you turn it off? or are you asking how to set the time and date?
If you're losing time and date when you turn the unit off, there's a coin cell battery on the main processor board that needs replacing.
If you just want to set the time and date - Press "SHIFT" and 12 lead keys at the same time. select "7" for date and time, use the return key to select date or time
Jan 31, 2014 | Ge Medical Systems Ge Marquette Mac 1200...
I need user manual GE marquette max-1 stress test treadmill
Hi...
i would be appreciate those who sends me MAX 1 stress test (workstation) service manual..... i tried a lot to find it but could not make it... do help me. thank you.
Apr 04, 2013 | Ge Medical Systems Ge Marquette Mac 1200...
Error 00161 00163
[CHANGE YOUR CMOS BATTER WHICH IS INSIDE YOUR CPU CASE]
I do not think you fixed the CMOS battery - (backup battery = CMOS battery)
According to the error codes, you have a dead backup battery and the time is not set. Makes sense?
161
(Dead battery.) 1. Go to Checking the Backup Battery
2. Backup battery.
3. System board.
163
(Time and date were not set.) 1. Set time and date.
2. System board.
Go to www.ibm.com Find and download the user manual, and the "hardware maintenance manual."
Do you know how to get into bios/setup?
Start with the machine OFF. HOLD DOWN and CONTINUE TO HOLD THE "F1" key.
WHILE STILL HOLDING "F1", turn the power on, and CONTINUE TO HOLD "F1"
This will get you into the bios "setup." You should check the date, bootup order, etc, and reset.
I would check the "wire" you think you reconnected---you may just not have actually reconnected it.
The "hardware maintenance manual" shows you how to maintain this machine, and it explains the meaning of the error codes.
This will get you started on looking for the manual:
http://www-307.ibm.com/pc/support/site.wss/multiplefiledownload.do?validate=true
May 16, 2010 | IBM ThinkPad 380ED
Troubleshooting
What is the fault detail, losing time & date?
Bob - www.woodenmen.co.uk
Apr 24, 2010 | Ge Medical Systems Ge Marquette Mac 1200...
Hello my ibm thinkpad 600E will not come up. it says error 00161 and 00163. what do i need to do?
Start with the machine OFF. HOLD DOWN and CONTINUE TO HOLD THE "F1" key. WHILE STILL HOLDING "F1", turn the power on, and CONTINUE TO HOLD "F1" This will get you into the bios "setup." You should check the date, bootup order, etc, and reset. I would check the "wire" you think you reconnected---you may just not have actually reconnected it.
According to the error codes, you have a dead backup battery and the time is not set. Error: 161
2. Backup battery.
3. System board.
Error: 163
2. System board.
Jul 14, 2009 | IBM Computers & Internet
IBM ThinkPad 600E 2645 PC
the following data is from the hardware maintenance manual for the thinkpad 600 series and is readily available from http://www.lenovo.com/support
Symptom or error FRU or action, in
sequence
161
Dead battery.
1. Go to “Checking the
backup battery” on
page 12.
2. Backup battery.
3. System board.
163
2. System board.
173
Configuration data was lost.
1. Select OK in the error
screen; then set the
time and date.
2. Backup battery.
3. System board.
192
Fan error.
1. Go to “Testing the
computer” on
page 7.
2. Measure the voltage of
the backup battery. If
the voltage is not
correct, replace the
backup battery.
3. Fan.
4. System board.
Oct 03, 2008 | IBM ThinkPad 600E 2645 Notebook
Fuji finepix f610
no backup, just re-set the time and date as prompted when you turn the camera back on, it takes 1 minute....!
Sep 16, 2008 | Fuji FinePix F610 Digital Camera
Error
I do not think you fixed the CMOS battery - (backup battery = CMOS battery) According to the error codes, you have a dead backup battery and the time is not set. Makes sense? 161
2. Backup battery.
3. System board.
163
2. System board.
hope this will help.
Jun 06, 2008 | IBM ThinkPad 380ED
Ge Medical Systems Ge Marquette Mac 1200 Interpretive Ecg Logo
310 people viewed this question
Top Ge Medical Systems Medical Experts
Harrie
Fred Murdock
Fred Murdock
chuck ringwood
chuck ringwood
Are you a Ge Medical Systems Medical Expert? Answer questions, earn points and help others
